Toymods » The Outhouse » switches (electrical gadgets)
SupraPete
switches (electrical gadgets) Tue, 09 August 2005 00:30 Go to next message
Still building the internet cafe. We're thinking of re-routing all the reset buttons to the main desk. We'll probably end up using some cat5 cable and splitting it to the seperate boxes for extending the 2 wires.
I thought with the Jaycar and other different backgrounded people here we might find a viable (and interesting) solution.
Question is:
Is there a pre-built switchboard that has up to 30 buttons on it?
- Buttons need to be spring loaded (don't stay switched)
- Enough room to be used by fingers (ie. not dil switches)
- PC number needs to be displayed somehow
- can't be too big, can be in one long line, or 2 or 3 rows of buttons
- preferable mounting position will be to the under side of a MDF table
- extensible would be great, eg. put another board next to it and get 60 reset buttons.
- wiring can't be too difficult (I can solder and use heat shrink well)
- CHEAP (max $50)
Any other options? Like 30 little red buttons and wire them all individually and hot-glue them to the top of the table.
Also a way to have the wires inside the box to be unpluggable. The connection to the motherboard is a 2 pin connector, I'd like to have the normal reset wires start there and run to the outside of the box where there needs to be a plug where I can plug these extended wires into.
river
Land of Oz
Re: switches (electrical gadgets) Tue, 09 August 2005 00:57 Go to previous messageGo to next message
I assume your main desk (ie where you sit) will have a PC that you will use. I also assume the cafe PCs will be connected onto a LAN of some sort? If so, there's got to be some remote boot software around. All you need do is send the reboot command to the appropriate PC. We had software that did this back in the old OS/2 days, so I assume the latest OS will have this ability with some from of Remote PC software. Certainly easier than hardwiring a stack of switches and then getting some smarts to display what machine it is that is being rebooted.
Also, with remote PC software oyu can check what the cafe PCs are doing so you can see if the users are loading porn or doing other nefarious things to your machines.
seeyuzz
river
SupraPete
Re: switches (electrical gadgets) Tue, 09 August 2005 01:00 Go to previous messageGo to next message
Yeah we're totally covered in that regard, we can take full control of any of the PCs on the floor.
Main use for these reset buttons will be if the PC locked up or blue screened (god forbid) or isn't accessable via remote desktop.
All the PCs are totally enclosed and locked in black boxes (to stop tampering), so we can't press the reboot button on the actual PC.
[Updated on: Tue, 09 August 2005 01:01]
Squid
Re: switches (electrical gadgets) Tue, 09 August 2005 02:00 Go to previous messageGo to next message
You can set windows up to automatically reboot after a blue screen...
AE82Gunner
Re: switches (electrical gadgets) Tue, 09 August 2005 02:38 Go to previous messageGo to next message
Where abouts are you setting up a cafe ??
I suggest you take a look at http://www.headshotgames.com/ they are in sutherland shire.
They have custom made boxes that are stuck to the side of the monitor with speaker connection and reset buttons, not sure if they will want to share info but if you should call or want to speak to someone there ask for andrew.
AE82Gunner
Re: switches (electrical gadgets) Tue, 09 August 2005 02:39 Go to previous messageGo to next message
Oh yeah they have webcam Smile http://www.headshotgames.com/shop_web_cam.htm
SupraPete
Re: switches (electrical gadgets) Tue, 09 August 2005 03:05 Go to previous messageGo to next message
Yeah headshots are nice. Thats where we got our idea for the boxes.
Our internet cafe is in Revesby.
Re: switches (electrical gadgets) Tue, 09 August 2005 03:50 Go to previous messageGo to next message
pete - contact Witzl's consulting services and we will work a solution for you.
PM your address and ill ex-post you a catalogue with some suggestions for switches and ideas of mine for working your idea.
Will be (cheap)^2
SupraPete
Re: switches (electrical gadgets) Tue, 09 August 2005 03:54 Go to previous messageGo to next message
Great. Knew you or your sidekick would know something I could use.
PM sent.
I went through the online thing for Jaycar and all I could find that was close was dil switches or keypads.
Toobs
Re: switches (electrical gadgets) Tue, 09 August 2005 03:59 Go to previous messageGo to next message
Just get an instrument case and put 30 odd switches in it.
Switches SP0710 $0.95/pc
Enclosure HB6094 $14
Wire WB1702 $23/roll
Or instead of the wire you could use one of the spare pairs on your cat5 cable... so long as the router is fairly close to your main desk.
SupraPete
Re: switches (electrical gadgets) Tue, 09 August 2005 04:16 Go to previous messageGo to next message
cool so your reccommendation is
http://www.jaycar.com.au/products_uploaded/productLarge_8063.jpg
with 30 of
http://www.jaycar.com.au/products_uploaded/product_4177.jpg
total of $45ish.
sounds good. Sounds like a lot of work too. I crimped 30 cat-5 cables in one sitting. that was fun Confused
Toobs
Re: switches (electrical gadgets) Tue, 09 August 2005 04:43 Go to previous messageGo to next message
I was thinking just solder the spare pins on the network card to the lead for the reset switch on the case.
Then just do the same from the switch to the instrument case... depending on how much room is in your switch you might even be able to mount the push button switches inside your network switch.
SupraPete
Re: switches (electrical gadgets) Tue, 09 August 2005 04:57 Go to previous messageGo to next message
I thought thats what you were hinting at - using the same cat-5 cables already going to the PCs.
by this page
http://www.bluemax.net/techtips/networking/Wiring_ Tips/Wiring100TX/colorcodestandards.htm
there are only 4 wires used for Standard Ethernet wiring. so in affect I could put 2 switches on each cat-5. So I could put power AND reset at another location.
This would mean ripping into my nice crimp-job that is currently working, but I'd much prefer this to running another 8 cat-5 cables through the room.
I'll have another look in Jaycar to see if there is some buttons with wires already attached, as I need some more length at the hub.
Dale_ta22
Forster NSW
Re: switches (electrical gadgets) Tue, 09 August 2005 07:22 Go to previous messageGo to next message
Not being rude, but that sounds pretty damn extreme and like a lot of work.
Worst case scenario you might have to walk to the machine, turn the power point off and back on, or just unplug, and re-plug it in?
I just can't see it being a very common occurance that you'll need to hard reboot machines in this era. Especially if it's only an internet cafe. Or is it gaming, too? Even still...
Squid
Re: switches (electrical gadgets) Tue, 09 August 2005 07:44 Go to previous messageGo to next message
I just did a search on "remote reboot" and found cards that trigger a remote reboot using the unused cat5 wires. The card is a passthrough type card, so you connect your network in to this car, and its output to the network card.
Then you install a software package on the front desk and viola your away!
SupraPete
Not being rude, but did you read the posts above?
All the PCs are enclosed in locked boxes so that the occupants can't touch/tamper/unplug/fuck with.
And with 16 PCs (27 PCs later) there is alyways something that happens or goes wrong, even in my testing with mates. Although they reboot themselves after blue-screens and are pretty good at recovering from game errors (thanks windows XP) there are still situations where stuff is going to happen.
Fingers crossed I'll never need to do a single reboot, but if I do, I don't want to disrupt 6 people to bring open the door to the box and press the reboot button.
SupraPete
Re: switches (electrical gadgets) Tue, 09 August 2005 07:45 Go to previous messageGo to next message
Squid wrote on Tue, 09 August 2005 17:44
Thats what I want to hear! I'll go google...
Re: switches (electrical gadgets) Tue, 09 August 2005 09:05 Go to previous messageGo to next message
....profit
SupraPete
Re: switches (electrical gadgets) Tue, 09 August 2005 22:46 Go to previous messageGo to next message
Had a look at those remote-reboot things, looks like they cost more than the PCs themselves.
I'll go back to wiring them in myself I think ...
Toobs
Re: switches (electrical gadgets) Tue, 09 August 2005 23:13 Go to previous messageGo to next message
Don't rip apart the crimped cat5 just solder from the pins on the network card that are unused to the reset switch and then do likewise on the switch.
Squid
Re: switches (electrical gadgets) Tue, 09 August 2005 23:35 Go to previous messageGo to next message
SupraPete wrote on Wed, 10 August 2005 08:46
Yeah I kind of worked that out after my post, not an entirely cost effective solution!! I'm not sure who would be willing to pay that much for the solution, there has to be a better way!
SupraPete
Re: switches (electrical gadgets) Wed, 10 August 2005 00:31 Go to previous messageGo to next message
Toobs wrote on Wed, 10 August 2005 09:13
Sounds ... HARD. All the network cards are onboard. so would be soldering directly onto the motherboard. But would make the whole process MUCH neater and re-pluggable.
I can DEFINATELY see the benefit of doing it this way though. I'll take it into consideration. I might pull apart the switch and see if I can get to the pins on it.
Anyone know if I can get a bundle (like 30) of the reset wires and connectors?? (the ones that plug into the motherboard)
pic stolen from another thread:
http://img32.imageshack.us/img32/4979/comp12ej.jpg
the wires/plugs on the bottom left.
mynameisrodney
Kellyville, Sydney
Re: switches (electrical gadgets) Wed, 10 August 2005 00:37 Go to previous messageGo to next message
go around at council cleanup time and pickup everyones broken comps. then rip the wires out.
SupraPete
Re: switches (electrical gadgets) Wed, 10 August 2005 01:35 Go to previous messageGo to next message
Yeah was thinking that. I've probably got a few mobos lieing around. But they won't be nice and colour coded and won't say "reset" on them etc.
If I can get a bundle of 30 for $2, then its worth getting.
Squid
Re: switches (electrical gadgets) Wed, 10 August 2005 03:11 Go to previous messageGo to next message
You could always use a trained monkey Smile
Has the added bonus of being able to teach it to steal wallets!
unforgiven
February 2005
Re: switches (electrical gadgets) Wed, 10 August 2005 03:22 Go to previous message
And do little dances for money!!
Make sure you tell us when its opening coz i'll be there!
Previous Topic:Doug!!!!
Next Topic:New Dori Website!!!
Current Time: Fri Nov 20 23:50:28 UTC 2026
Total time taken to generate the page: 0.0061390399932861 seconds
