Toymods » Tech & Conversions » cutting/crafting/drilling thin metal
styler
cutting/crafting/drilling thin metal Tue, 09 August 2005 02:31 Go to next message
is a dremel any good?
Re: cutting/crafting/drilling thin metal Tue, 09 August 2005 03:26 Go to previous messageGo to next message
I'm having trouble finding suitable attachments for mine to cut metal. Seems all the grinding and sanding disc's I find just get chewed up to nothing when I try em on metal.
With the right attachments I think it be good.
Youngy
Eskilstuna, Sweden
Re: cutting/crafting/drilling thin metal Tue, 09 August 2005 04:31 Go to previous messageGo to next message
What's wrong with a 1mm thick cut off blade on a 4 inch grinder?
acreese
Re: cutting/crafting/drilling thin metal Tue, 09 August 2005 04:46 Go to previous messageGo to next message
Tin snips Razz
Accuracy was not mentioned in your title...
styler
Re: cutting/crafting/drilling thin metal Tue, 09 August 2005 06:43 Go to previous messageGo to next message
yeah so far i have tin snips, jig saw, drill, one ended hacksaw,
die grinder and power roofing shears but still have a hard time sometimes cutting metal.
the dremel has this multicutter that is a sideways drill, like a router and has a frame to hold it perpendicular on surfaces if needed. other than that some power/air nibblers may be the go. or some friggin huge holesaws.
im looking at a good finish like for body work etc
clubagreenie
1st street on the right
Re: cutting/crafting/drilling thin metal Tue, 09 August 2005 07:12 Go to previous message
Do you want to cut shapes or just round holes?
You can get die punches that you drill a smaller hole through the panel, then insert a bolt through the punch and screws into a die on the other side. Works really well but only does round holes, unless you make your own.
You can get small grinding stones in small sets from the markets or bunnings that work reasonably well. The las set I had were used on stainless and lasted longer than I thought.
Previous Topic:wjich way does clutch go in
Next Topic:AE82 RADIATOR
Current Time: Sun Oct 25 04:35:49 UTC 2026
Total time taken to generate the page: 0.0047471523284912 seconds
