Toymods » Tech & Conversions » Handbrake light flickering
RAV-GT4
Toymods member
Rydalmere, NSW
Handbrake light flickering Tue, 09 August 2005 05:31 Go to next message
On my dash warning light panel, the handbrake light flickers (once, momentarily) when I give the RAV a bit of a hit in 1st gear. It seems to do it on uphills and when the car shifts weight momentum from rear to front, as a result of gear changing. The only thing I can think of is the handbrake switch/button (which is under the handbrake lever), but it takes some force to lift the lever and actuate the button that the handbrake hits, to make the light go on. I'm wondering if there's somewhere else a button or some other type of trigger for the handbrake warning light might be.
Any clues? Confused
Instigator_PsY
Melbourne Victoria
Re: Handbrake light flickering Tue, 09 August 2005 05:35 Go to previous messageGo to next message
Check your brake fluid.
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Handbrake light flickering Tue, 09 August 2005 05:46 Go to previous messageGo to next message
Fluid was only just replaced, along with the new set of front pads... but I'll suss it out. Is this characteristic of low fluid or fluid movement?
jonchai
Adelaide - Race Central
Re: Handbrake light flickering Tue, 09 August 2005 06:03 Go to previous messageGo to next message
Must be a Rav4 thing coz my parents have a 1999 Rav4 and it happens as well.
does it happen less when you drive slowly? and more when you granny shift it?
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Handbrake light flickering Tue, 09 August 2005 06:10 Go to previous messageGo to next message
Granny shift? Please explain... Confused
It only happens when I give it a hit in first... the boost makes the back end squat, so fluid level could be an issue to consider. Nod
Instigator_PsY
Melbourne Victoria
Re: Handbrake light flickering Tue, 09 August 2005 07:31 Go to previous messageGo to next message
I had a similar problem in my sprinter the fluid was only a few mm below the max line and when i would turn hard, brake hard (shift weight around) the brake light would come on, i topped up the fluid and it stopped.
[Updated on: Tue, 09 August 2005 07:33]
EVOSTi
cambo
      no
Re: Handbrake light flickering Tue, 09 August 2005 11:06 Go to previous messageGo to next message
yeah the handbrake light is also the warning light for the foot brakes, the light will come on if there is low fluid or i think some master cylinders have a pressure differentiating valve? anyway what your describing could only be the low level indicator light, put more fluid in it, above the max line if you have to Smile
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Handbrake light flickering Wed, 10 August 2005 05:19 Go to previous messageGo to next message
Thanks guys...
Cheers. Wink
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Handbrake light flickering Fri, 12 August 2005 06:54 Go to previous messageGo to next message
Brake fluid it was... Wink thanks.
It toook in a little bit more than I thought.... the level seemed to be fine, but pour some in and the level would drop a bit as it took it in. I gave it a fill up almost to the top of where the cap sits, no prob's thus far. Very Happy
Cheers.
Re: Handbrake light flickering Fri, 12 August 2005 07:24 Go to previous messageGo to next message
Just watch the level when you change the pads.
You'll find that when you push the pistons back in the fluid level will rise, and possibly overflow.
Worth noting.
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Handbrake light flickering Fri, 12 August 2005 10:07 Go to previous messageGo to next message
Thanks for that dude, they've only just been changed over... so I guess some of the fluid will probably diminish slightly with time and usage?
Re: Handbrake light flickering Fri, 12 August 2005 10:18 Go to previous message
Yes it will slightly drop over time.
But not a huge amount.
And that could mainly be due to pads being worn.
Previous Topic:Not purely Car related (EPC)
Next Topic:Wiring a Tacho
Current Time: Fri Nov 20 20:02:23 UTC 2026
Total time taken to generate the page: 0.0067338943481445 seconds
