Toymods » Tech & Conversions » removing crank pulley from 1G
hickoz_bro
removing crank pulley from 1G Tue, 09 August 2005 05:49 Go to next message
hey guys, once again i stuck... gotta get the crank pulley off to replace the timing belt, though i can't undo the bolt for starters, from what i can see there's 2 holes on either side of the center bolt, and if i had a welder i'd make a 'C' spanner of sorts up to keep the pulley still while i undo the bolt... has anyone got any suggestions, i've tried putting it in gear, but it still just pushes the car... tried sticking something in the hole to wedge it on the engine behind, but i only get the smooth timing cover...
suggestions?
Re: removing crank pulley from 1G Tue, 09 August 2005 06:03 Go to previous messageGo to next message
Put a breaker bar on the crank pulley bolt. Wedge it against something. Put in neutral, crack the starter, should take a whole half a second to come undone.
hickoz_bro
Re: removing crank pulley from 1G Tue, 09 August 2005 06:16 Go to previous messageGo to next message
and if the car isn't running?
Re: removing crank pulley from 1G Tue, 09 August 2005 06:30 Go to previous messageGo to next message
Does it have a starter connected? If so, connect it's main line to the battery and give the starter pin on the engine/dash plug 12V.
STR8 2.8
Re: removing crank pulley from 1G Tue, 09 August 2005 07:18 Go to previous messageGo to next message
put it in 5th and chock the wheels
hickoz_bro
hmmmm fair enough... good point, i'll give that a shot, how about getting the pulley off with out a puller?
STR8 2.8
Re: removing crank pulley from 1G Tue, 09 August 2005 07:19 Go to previous messageGo to next message
it can be done, lots of jiggling.
but just hire a puller ($10) you'll be glad you did.
Dale_ta22
Forster NSW
Re: removing crank pulley from 1G Tue, 09 August 2005 09:02 Go to previous messageGo to next message
justcallmefrank wrote on Tue, 09 August 2005 16:03
Amen to that!
Re: removing crank pulley from 1G Tue, 09 August 2005 09:42 Go to previous messageGo to next message
STR8 2.8 wrote on Tue, 09 August 2005 15:19
Or buy one for $20 like I did and have one forever Razz
Big T
Re: removing crank pulley from 1G Tue, 09 August 2005 10:04 Go to previous messageGo to next message
hickoz_bro wrote on Tue, 09 August 2005 17:18
Just buy one of them from supercheap. Best $25 you'll ever spend. It seriously just makes things a billion times easier.
Eddie.
rxbenny
Perth WA
Re: removing crank pulley from 1G Tue, 04 October 2005 14:38 Go to previous messageGo to next message
just wanting to clarify this will work on a 4age also?
and how to tighten?
chock in 5th?
Dale_ta22
Forster NSW
Re: removing crank pulley from 1G Tue, 04 October 2005 22:50 Go to previous message
Will work on a 4age! To tighten, use some loctite, put it in gear and get someone to step on the brake while you tighten it up. A lower gear would be better to use, I tend to think
[Updated on: Tue, 04 October 2005 22:51]
Previous Topic:ST185 Boost Problem
Next Topic:CA18DET into KE30/35 anyone done it?
Current Time: Mon Oct 26 13:47:15 UTC 2026
Total time taken to generate the page: 0.0064678192138672 seconds
