Toymods » Tech & Conversions » ma 70 problems
Stomps
Canning Vale WA
ma 70 problems Tue, 09 August 2005 07:06 Go to next message
hey i got a squeeling noise coming from the back of my motor/ front of gearbox.. (r154 manual) sometimes it has problems going into gear when cold and on really cold starts it makes a noise like brakes squeeling for a while then it goes away..
also when i get on boost it feels like it bogs down hard between 5-10psi but after that it pulls ok (running 15psi) however it still feels a little sluggish even on full boost..
Was told it could be some gasket goo that got in the way when putting the intake manifold together (2 piece) that might explain the bogging down but that noise sounds evil..
any hints would be appreciated..
V8_MA61
Re: ma 70 problems Tue, 09 August 2005 12:45 Go to previous messageGo to next message
that sounds like clutch issues to me...hows your fluid levels, fluid condition, slave cylinder condition? did you do this manual conversion or has the box never been removed?
Stomps
Canning Vale WA
Re: ma 70 problems Tue, 09 August 2005 14:48 Go to previous messageGo to next message
did the manual conversion, got a used slave cylinder-- reconditioned and cleaned it.. as new.. fluids are full and all connections seem ok..
was thinking clutch would explain the gear problems, but what about the noise and bogging down.. although it feels like clutch slip, it still pulls afer 10psi..
my bro mentioned something about the thrust bearing maybe being fucked, do you know anything about that??
V8_MA61
Re: ma 70 problems Wed, 10 August 2005 08:57 Go to previous messageGo to next message
yep they make squealing noises Smile that is the thrower bearing he is referring to, it is attached to the clutch fork.
Allan
Re: ma 70 problems Wed, 10 August 2005 09:14 Go to previous messageGo to next message
could be pilot baring
Stomps
Canning Vale WA
Re: ma 70 problems Wed, 10 August 2005 09:40 Go to previous messageGo to next message
ok, i gonna replace the clutch anyway, do yous know how much each would be and how bad it is..
also does anyone have a good clutch?? or can get one..
and a lightened flywheel would help too Razz
cheers for your help if you have any other ideas please help..
car is up for sale and i need to fix it before i sell it
Allan
Re: ma 70 problems Wed, 10 August 2005 09:59 Go to previous messageGo to next message
try supramania or supraforums you will be pushing shit uphill to get more then "replace it with a fooly sik 1jayzee" here
Stomps
Canning Vale WA
Re: ma 70 problems Wed, 10 August 2005 10:28 Go to previous message
yeah true, hey the motor is fucking strong just got some teething problems.. cheers for your help,
P.S if i was gonna get serious i would put in a 2j not 1j Razz
Stomps
Previous Topic:weird electrical problem
Next Topic:1JZ Flywheel Weight
Current Time: Sat Nov 21 00:25:07 UTC 2026
Total time taken to generate the page: 0.0055780410766602 seconds
