Toymods » Tech & Conversions » putting new cams in a 2tg
lilcrash
ipswich queensland
putting new cams in a 2tg Tue, 09 August 2005 11:12 Go to next message
wat is needed to put bigger cams in?? wat do i need to do??
thanx
Re: putting new cams in a 2tg Tue, 09 August 2005 11:22 Go to previous messageGo to next message
wat iz it dat youz wanna get from it??
lilcrash
ipswich queensland
Re: putting new cams in a 2tg Tue, 09 August 2005 11:29 Go to previous messageGo to next message
i have a pair of 288 degree cams i wanna put in but apparently i cant just bolt them in. so wat do i do??
(also there is a possibility that my possible stock cams arent stock as i have too much hp for a stock engine apparently.)
thanx
boofis
MELBOURNE
Re: putting new cams in a 2tg Tue, 09 August 2005 21:34 Go to previous messageGo to next message
oldcorollas wrote on Tue, 09 August 2005 21:22
Laughing
styler
Re: putting new cams in a 2tg Wed, 10 August 2005 00:26 Go to previous messageGo to next message
maybe someone else knows more to it but i cant see why you cant bolt them in, they will fit, its the rest of the setup that has to be modified - ie rebuilding the head and clearances, shims and whatever as well as changing some settings on the dizzy and carbs to suit the cams. thats my educated guess.
the 2tg stock series of cams had some sets with pretty aggressive grinds and as time progressed emissions control and head design saw they got toned down a lot. so there are a lot of stock cams with aggressive grinds on them that can be put into your later model 2tg engine.
you can also get a regrind for about 100 per cam in brisbane im told, which can be whatever specs you want.
on a turbo street engine, ie 3tgteu you wont be able to run a very agressive cam grind
[Updated on: Wed, 10 August 2005 00:32]
dayzii
Perth W.A
Re: putting new cams in a 2tg Wed, 10 August 2005 02:44 Go to previous messageGo to next message
Wont larger cams throw out your timing?
Jezza
Re: putting new cams in a 2tg Wed, 10 August 2005 02:46 Go to previous messageGo to next message
if u have vac advance they will, as there is erratic vacuum at lower rpm's due to overlap (this is talkin big cams though) same goes for MAP sensors on cars with big cams, and big ported rotors...
[Updated on: Wed, 10 August 2005 02:48]
Re: putting new cams in a 2tg Wed, 10 August 2005 04:06 Go to previous message
lilcrash wrote on Tue, 09 August 2005 21:12
thanx
depending on how big they are in terms of duration OR lift, you may or may not have to do many things
if you double the lift, you will need to do different things to if you are getting 320deg duration cams...
Previous Topic:AE86 brake rotors
Next Topic:ECU and Cruise Control Q RE JZA70
Current Time: Mon Oct 19 10:57:10 UTC 2026
Total time taken to generate the page: 0.089624881744385 seconds
