Classifieds » Engines, Accessories and other Mechanicals » 18RG FS, and 18RG EFI set also for sale.
o_man_ra23
Townsville North Qld
icon10.gif  18RG FS, and 18RG EFI set also for sale. Tue, 09 August 2005 11:29 Go to next message
as sed, i have both an 18RG and an 18RG efi setup for sale.
the engine is yet to be built, but will be built to buyers spec. has a 88230 block (yes, 9.7:1 pistons), where the piston and rod assy's will be balanced, will have new rings and bearings, crank has been mike'd and linished, and the rear mainseal groove has been metal sprayed and resurfaced about 5000 k's ago. head will be machined, and block decked, new valves, springs and guides, 230 cams (big lift and duration), and some porting and polishing done. will have new timing chains and serviced upper timing chain tensioner
can be supplied with points or electronic dizzy, and mid or rear sump and pickup. cams will be timed to buyers spec and dizzy will be timed well enuf to start.
motor supplied with no carbs or extractors. resurfaced flywheel will be supplied. other mods can be done upon request from buyer and at buyer's cost. asking $1400 for motor as described.
EFI setup avail to suit 18RG does not include pump, and fuel pressure regulator is suspect. Injectors have been fully cleaned, tested and serviced, and are in top notch cond. includes near new air and fuel filters, full loom, programmable ecu, thermostat housing which has been modified to fit the fuel rail. setup is currently running in an RA23 but will be removed sometime this week. asking $750 for efi setup.
asking $2000 together, and extractors can be sought to suit if desired.
email O_man_ra23@yahoo.com.au, or call me on 0402710252 if you are interested.
Cheers Owen.
Attachment: 18rgefi5.jpg
(Size: 81.87KB, Downloaded 53 time(s))
[Updated on: Tue, 09 August 2005 11:34]
o_man_ra23
icon10.gif  Re: 18RG FS, and 18RG EFI set also for sale. Thu, 11 August 2005 06:52 Go to previous messageGo to next message
bump... gee this board moves quick
cmon ppl, help out a poor uni student would you.
o_man_ra23
icon10.gif  Re: 18RG FS, and 18RG EFI set also for sale. Thu, 18 August 2005 13:29 Go to previous message
bump, offers around $650 being taken for the efi, price on engine is solid.
Previous Topic:**SOLD**
Next Topic:7mge mx83 auto gearbox
Current Time: Sun Oct 18 08:03:08 UTC 2026
Total time taken to generate the page: 0.017944097518921 seconds
