Toymods » Tech & Conversions » Plz Help!!! ST-162 Air Con n Heater problem!!!
RavnuZ
February 2005
Plz Help!!! ST-162 Air Con n Heater problem!!! Tue, 09 August 2005 12:15 Go to next message
Hi all,
i jus bought an 86 Celica ... love it n all BUT the heater and AC dont work Sad ... u can flick the switches all u want but nothing!!! ive looked at the fuses but they are all good ... the only heating i have in my car is if i open the vent to let in hot air from the engine which aint tht efficient Sad
Plz help or recommend a good repair person ... im in Oakleigh, Melbourne.
Cheers!!!
warrior
Sydney / NSW
Re: Plz Help!!! ST-162 Air Con n Heater problem!!! Tue, 09 August 2005 12:36 Go to previous messageGo to next message
are you getting power to the fan control, eg, OFF,LOW,HIGH etc.
when u turn that on do you get air?
RavnuZ
February 2005
Re: Plz Help!!! ST-162 Air Con n Heater problem!!! Tue, 09 August 2005 12:41 Go to previous messageGo to next message
warrior wrote on Tue, 09 August 2005 22:36
no mate Sad nothing at all ... only the backlights work thts it ... the fan duznt work nor do the AC buttons ... its like DEAD Sad !!!
warrior
Sydney / NSW
Re: Plz Help!!! ST-162 Air Con n Heater problem!!! Tue, 09 August 2005 12:48 Go to previous messageGo to next message
have you checked the relays under the hood?
and im pretty sure you have checked the fuses at the kick panel near the accelarator pedal, (but doesnt hurt to ask)
you arent getting any power which constitiutes to a fugged relay or fuse.
Karl
RavnuZ
February 2005
Re: Plz Help!!! ST-162 Air Con n Heater problem!!! Tue, 09 August 2005 13:16 Go to previous messageGo to next message
warrior wrote on Tue, 09 August 2005 22:48
Karl
hey mate,
yep i checked the fuses at the kick panel ... no worries for askin ... im a noob newayz Embarassed ... and by "relays" do u mean the other fuse box on the lower right corner of the hood? If so, i checked those as well but they are all good Confused ... i hope i didnt check the relays Very Happy it gives me hope tht i may still fix it myself
smashed_wombat
Re: Plz Help!!! ST-162 Air Con n Heater problem!!! Wed, 10 August 2005 08:18 Go to previous messageGo to next message
unplug the fan, turn the switch on and see if you're getting voltage at the plug with a multi-meter. If there is voltage, then the fan motor is dead or the fan is full of dirt. If there's no voltage then you've blown a fuse / relay or have a broken circuit somewhere. Good luck!
- Andy
RavnuZ
February 2005
Re: Plz Help!!! ST-162 Air Con n Heater problem!!! Wed, 10 August 2005 14:55 Go to previous messageGo to next message
Thanks Andy!!!
ill try wat u sed n ill keep my fingers crossed ... HOpe it works out ... CHeers bro!!!
Thanks for ur help!!!
Oz
trdcmy
West Sydney
July 2005
Re: Plz Help!!! ST-162 Air Con n Heater problem!!! Wed, 10 August 2005 23:22 Go to previous message
i had the same problem what mine was was the relay box itself was stuffed, it could have burnt up a section of the board in the box,
Previous Topic:4a T50's? (ae86/ae71)
Next Topic:3tgte to 3sgte injector
Current Time: Sat Nov 21 06:15:59 UTC 2026
Total time taken to generate the page: 0.063915014266968 seconds
