Toymods » Tech & Conversions » 2s in an 86 Corona auto
Anakist
Rockhampton CQ
2s in an 86 Corona auto Tue, 09 August 2005 12:32 Go to next message
The 2s is eating fuel and oil and is way old and needs to go. What can I swap it with?
I don't need heaps of power, I am basically looking for an EFI engine with the same or slightly more power to throw in and mate to a 5 speed. A 1.6 or 1.8 with the same power would be good. Going for a miser car.
James
SA63
melbourne.vic.au
August 2005
Re: 2s in an 86 Corona auto Tue, 09 August 2005 13:19 Go to previous messageGo to next message
If you can source an SA63 with an Automatic you might be able to get away with converting the engine, just that there might be minor wiring for the automatic overdrive and a change of the bottom of the shifter as the SA63 has an overdrive button where the ST141 doesn't have anything for the button. Though I can be wrong, any correct me on this?
Anakist
Rockhampton CQ
Re: 2s in an 86 Corona auto Wed, 10 August 2005 04:14 Go to previous messageGo to next message
What will I find that in? I am going to transplant in a manual so overdrive etc won't matter.
What is a strong 1l – 1.8l EFI motor suitable for forced induction? What series is interchangeable with the 2s? Will I have to find a _s-t or something like that? That will probably be a good mix of power and economy.
James
Re: 2s in an 86 Corona auto Wed, 10 August 2005 05:48 Go to previous messageGo to next message
Find yourself a wrecked manual RT142 Corona with a 22RE in it.
Swap everything over.
Corona RT142
Campbelltown
Re: 2s in an 86 Corona auto Wed, 10 August 2005 05:51 Go to previous messageGo to next message
i think he said he wanted fuel economy Wink
Re: 2s in an 86 Corona auto Wed, 10 August 2005 05:59 Go to previous messageGo to next message
Well, the 22RE is gonna give better economy than the old 2S
Corona RT142
Campbelltown
Re: 2s in an 86 Corona auto Wed, 10 August 2005 06:02 Go to previous messageGo to next message
you reckon, mine uses around 12-15L in the city and 10-13 on the freeway per 100km.
[Updated on: Wed, 10 August 2005 06:02]
Re: 2s in an 86 Corona auto Wed, 10 August 2005 06:07 Go to previous messageGo to next message
You need to get it checked
Franks 21RC uses less than that.
Re: 2s in an 86 Corona auto Wed, 10 August 2005 06:11 Go to previous messageGo to next message
Indeed, mine has even dipped down to 8.9l/100km on a massive highway run.
Corona RT142
Campbelltown
Re: 2s in an 86 Corona auto Wed, 10 August 2005 06:15 Go to previous messageGo to next message
the lowest i have seen is 10.5L driving to goulburn, sitting on 100kmph per hour at 2.4krpm.
The motor likes oil but the afr and dyno indicate that otherwise it is a ok i think the valve stem seals are gone, but so will the car in 6 months time so i can't be bothered fixing it.
Anakist
Rockhampton CQ
Re: 2s in an 86 Corona auto Thu, 11 August 2005 08:23 Go to previous messageGo to next message
The 22RE is a 2.4l though isn't it? I want 1.6 or 1.8.
James
toyotacorona
melb
Re: 2s in an 86 Corona auto Thu, 11 August 2005 10:37 Go to previous message
what about a 3tgte 1.8 turbo twin spark bolts in best bet would be a smashed corona gt from japan
[Updated on: Thu, 11 August 2005 10:38]
Previous Topic:1JZ INJECTOR HELP
Next Topic:4age big port and small port
Current Time: Fri Nov 20 23:50:12 UTC 2026
Total time taken to generate the page: 0.0047550201416016 seconds
