Toymods » Tech & Conversions » 2JZ rebuild
2JZ rebuild Wed, 10 August 2005 05:05 Go to next message
Has anyone here rebuilt a JZ series engine? I'm considering this for my 2JZ-GTE which is starting to get a bit tired (increased oil consumption, slight bottom end rattle) and I want to get an idea of the costs involved. Shouldn't need anything too major, just rings/bearings/seals/machining etc. No upgrades are planned at this point, I just want a freshen up.
I'd like to hear anyone's first-hand experiences!
Re: 2JZ rebuild Wed, 10 August 2005 05:20 Go to previous messageGo to next message
GT should know
1JZ.747
Osama's hideout
Re: 2JZ rebuild Wed, 10 August 2005 05:43 Go to previous messageGo to next message
not the indestructible 2j. whats happening norbie? has the engine done a lot of k's or do you have a suspicion of a fault some where.
i would suggest hardcore racing norbie, ask for Bruce, hardcore is located in logan just of the motorway. he rebuild 2j's on a daily basis.
Re: 2JZ rebuild Wed, 10 August 2005 05:48 Go to previous messageGo to next message
Hmmm.....well I have shelved plans to rebuild the 2JZGE - plan is to go sick on the VVTi 2JZGE and use the M800 to its fullest when I have my exams out of the way.
To do the things you want (a refresh), you'd be looking at 1500ish in machining and parts (excluding pistons), plus whatever to assemble. 2JZGE VRS kit is about $470 (I'd imagine the GTE one is about the same). Obviously the cost will go up depending on what fancy bits you want to add. Another 2G for Argo Rods, another 1200 for some forgies. Personally, if I were you, I would throw in a set of forged slugs - you're the kind of guy that might just bolt on a big fuck off turbo on the side of it one day. Laughing
Re: 2JZ rebuild Wed, 10 August 2005 05:49 Go to previous messageGo to next message
1JZ.747 wrote on Wed, 10 August 2005 13:43
Haha, it's not broken, it's just finally succumbing to Norbie's driving style and just wearing out Razz
Re: 2JZ rebuild Wed, 10 August 2005 06:20 Go to previous messageGo to next message
Yup, the front cut had 80k on the odometer when I got it (who knows how many km's it really did though) and I've been giving it arseholes ever since I installed it two and a half years ago. It's done an awful lot of work in that time, including several interstate trips, drag racing, circuit racing, mountain "cruises", and of course random Norbie-style shenannigans. Laughing
It's far from broken but it's showing definite signs of wear, so the longer I postpone a rebuild the more expensive it will be!
Thanks for the info GT, that's pretty much what I was expecting. It's tempting to go forgies but the stockers are reportedly good for a shiteload of power... not sure if it's worth the money since I genuinely don't want to build a big-hp lag-monster. If I ever go the single turbo route it will be something relatively small (eg GT30) and I reckon the stock pistons will be OK for that. On the other hand if I need new pistons anyway (and I really hope I don't), I might as well fork out the few hundred extra for forgies.
rob_RA40
c'town, NSW
Re: 2JZ rebuild Wed, 10 August 2005 06:22 Go to previous messageGo to next message
from all accounts ive heard norbie has a binary accelerator pedal Razz
Re: 2JZ rebuild Wed, 10 August 2005 06:24 Go to previous messageGo to next message
rob_RA40 wrote on Wed, 10 August 2005 14:22
And the clutch pedal?
V8_MA61
Re: 2JZ rebuild Wed, 10 August 2005 06:33 Go to previous messageGo to next message
anyone care to mention the head? That's where your expense will be if it is corroded and or bent (which unfortunately a lot of 1/2 cut motors are)
Also the cam bearings will need doing, valve grind (almost needs a full head rebuild if you ask me) as you had leaking stem seals.
Re: 2JZ rebuild Wed, 10 August 2005 06:46 Go to previous messageGo to next message
There's nothing to suggest the head is corroded or bent. It's never overheated badly and it's always had Toyota red coolant in it. New stem seals and a valve grind are a given though.
V8_MA61
Re: 2JZ rebuild Wed, 10 August 2005 06:52 Go to previous messageGo to next message
just dont be surprised if its corroded. after seeing the corrosion on my 7m head which had also always run coolant i would never suspect it wouldnt be corroded. but i guess you will soon know Smile
[Updated on: Wed, 10 August 2005 06:53]
Re: 2JZ rebuild Wed, 10 August 2005 07:52 Go to previous messageGo to next message
7M's are released with corrosion though.
V8_MA61
Re: 2JZ rebuild Wed, 10 August 2005 08:20 Go to previous messageGo to next message
dont expect your heads to look any better.
Re: 2JZ rebuild Wed, 10 August 2005 08:21 Go to previous messageGo to next message
I feel some jealously..
Skip
Re: 2JZ rebuild Wed, 10 August 2005 09:45 Go to previous messageGo to next message
If V8_MA61's 302 heads are corroded i think youll definitely find your 1UZ heads are aswell CrUZsida beacuse your engine is also V8. In the end I suppose everyone will have a corroded head if V8_MA61 did or his mates bestfriends brother in-law said he did too Laughing
Allan
Re: 2JZ rebuild Wed, 10 August 2005 09:51 Go to previous messageGo to next message
Norbie wrote on Wed, 10 August 2005 15:05
the joys of a second hand motor!
you will only have an idea of cost when you see what the bores are like and get everything crack tested etc..
Re: 2JZ rebuild Wed, 10 August 2005 09:53 Go to previous messageGo to next message
The blokes at Ford are clever buggers. They found a way to increase the efficiency of the internal combustion engine - not only does it release from the crankshaft, but also from the cooling system. See, every Ford engine block is actually a large battery as its primary purpose, and it is able to use river water as an electrolyte. This, in turn, forms large scale levels of corrosion in all parts of the vehicle to which it is attached, as well as unexplained heating and electrical problems.
I'll stop now before I get carried away Razz
wilbo666
Re: 2JZ rebuild Wed, 10 August 2005 09:58 Go to previous messageGo to next message
V8_MA61 wrote on Wed, 10 August 2005 18:20
Come and have a look in the water jacket of my 1jz Wink
It looks mint. As have all the 1jz'd I've seen at wreckers etc.
I suspect toyota are using a very high quality alloy Smile
V8_MA61
Re: 2JZ rebuild Wed, 10 August 2005 11:30 Go to previous messageGo to next message
wilbo666 wrote on Wed, 10 August 2005 19:58
have you actually had the head off the block? my 7m head was looking good too until i removed it and had a look near the combusion chambers
V8_MA61
Re: 2JZ rebuild Wed, 10 August 2005 11:32 Go to previous messageGo to next message
mrshin wrote on Wed, 10 August 2005 19:53
at least they dont blow headgaskets! Wink bar the xd-eb 250's.
wilbo666
Re: 2JZ rebuild Wed, 10 August 2005 12:09 Go to previous messageGo to next message
V8_MA61 wrote on Wed, 10 August 2005 21:30
I'll think about taking the head off when I get a BHG shall I? Razz
V8_MA61
Re: 2JZ rebuild Wed, 10 August 2005 12:11 Go to previous messageGo to next message
if you head is bent or too corroded that can still cause a BHG on a 1jz car. if it cant seal on both sides...how can it act as a gasket?
Re: 2JZ rebuild Wed, 10 August 2005 12:16 Go to previous messageGo to next message
V8_MA61 wrote on Wed, 10 August 2005 21:32
Darned shame they never made any 250s after the EA (except for old stock they continued to stick in the XF utes up until the XG) - darned shame they also STILL blow gaskets on new ones Razz
Mr DOHC
Re: 2JZ rebuild Wed, 10 August 2005 13:08 Go to previous messageGo to next message
if u are serious about getting it rebuilt, i.e. its gonna get done anyway, then pull it out and take it to a shop that does free strip and quotes, then if u dont like what they say, atke your boot o' JZ bits to he next shop and ask them
bring ti to my work, we do free stripping and quoting, and i can get u cheaper cost parts too Wink
wilbo666
Re: 2JZ rebuild Wed, 10 August 2005 13:12 Go to previous messageGo to next message
V8_MA61 wrote on Wed, 10 August 2005 22:11
OK Razz To start with my comment about taking the head off my 1jz when I get a BHG was a joke Smile 1JZ's don't really have a reputation for BHG's (metal headgasket stock is a wonderful thing Smile), I'm suspecting I won't be taking head off any time soon Wink
Another thing is, if an engine has a BHG you can expect head corrosion (such as you experienced). This is due to an acid (carbonic acid?, I'm not 100% sure what acid is formed) being formed when combustion gasses enter the water/coolant. This acid that is formed causes corrosion (such as you experienced). This is my understanding, and may indeed be incorrect Smile
dingaling
tas
Re: 2JZ rebuild Wed, 10 August 2005 14:48 Go to previous messageGo to next message
I suspect your 7m has had a few different coolants mixed with eachother at some stage blake.
If say the engine was using toyota red all it's life the inside of that 7m engine would look brand new.
I've got an old old subaru boxer engine that i picked up from somewhere, at least 28 years old that i opened it up and found the internals for where the coolant travels very CLEAN! brand new appearance still. The other subaru engine that my step dad thrashes around on old black oil and minerlised water is just rust and corrosion.
first time on these forums i've ever heard of a 2jz needing a rebuild Surprised Good statistics for the 2jz! Surprised
Re: 2JZ rebuild Thu, 11 August 2005 00:17 Go to previous messageGo to next message
Mr DOHC wrote on Wed, 10 August 2005 23:08
I might just do that! Where do you work exactly?
Note that none of this will happen until YelloRolla finishes rebuilding my 18R-G, so it could be a while yet (he's a busy man). Having both my cars off the road at the same time isn't a smart idea.
V8_MA61
Re: 2JZ rebuild Thu, 11 August 2005 06:58 Go to previous messageGo to next message
Norbie wrote on Thu, 11 August 2005 10:17
i know that feeling
edit: are you not going to rebuild it yourself?
[Updated on: Thu, 11 August 2005 06:58]
BlackSupra
Re: 2JZ rebuild Thu, 11 August 2005 08:51 Go to previous messageGo to next message
so what your saying is that your 2j will be rebuilt some time in the next eternity?
Mr DOHC
Re: 2JZ rebuild Thu, 11 August 2005 14:34 Go to previous messageGo to next message
i work at redlands engines, brett just had his RB30 bottom end done there, so he knows where it is
did u want me to get a basic cost on the build anyway
i know about the 2 cars off the road feeling, worse is when they both fuck up at the same time and u have no control over it Rolling Eyes
Re: 2JZ rebuild Thu, 11 August 2005 23:34 Go to previous messageGo to next message
Mr DOHC wrote on Fri, 12 August 2005 00:34
Ah ok, I drove him over there to pick up his parts so I know where it is too. Smile He says the job has cost him $350 so far but I'm guessing RB30 parts are a bit cheaper/easier to come by than 2JZ parts.
Yes please do! If the price isn't too bad and I can get it done quickly I might as well take the car off the road for a couple of weeks and just get it done.
Been there more times than I care to recall. Sad
[Updated on: Thu, 11 August 2005 23:35]
Blackers
Forrestdale W.A.
Re: 2JZ rebuild Fri, 12 August 2005 00:04 Go to previous messageGo to next message
Interestingly a good friend of mine has a 2JZ in his MK3 Supra with a GT40R turbo and standard everything except the exaust manifold, injectors and throttle body. Car makes 532rwbhp @ 5600rpm on 12psi boost. Big turbos don't always mean big lag, can't remember what torque it makes but to drive the car it doesn't feel much different from standard apart from the excessive wheelspin/OMG acceleration.
On the coolant note, I spent some time in the lab at work recently due to a broken leg (I'm a plant mechanic with the WA CAT dealer) where we test all the oil/coolant from the large earthmoving machines around the state. The customer sends us a sample, we analyze it thru a series of tests and send em back the results. Coolant colour is not a good indication of it's condition, the nitrites (which provide the corrosion inhibitor) in the coolant have to be within certain levels or else there is a good chance corrosion will occur. You can actually see over a period of time the degree in which a coolant loses it inhibitor capacity, with earthmoving they add a coolant extender to prolong the life of the coolant (imagine paying to change 350l of coolant) and the CAT stuff often lasts for 10,000hrs if it's maintained. You can actually get your coolant analyzed the same way but it's about $22, prolly cheeper just to change it!
Mark
quest
u.s.a. south
Re: 2JZ rebuild Sat, 13 August 2005 17:18 Go to previous messageGo to next message
what about the dealer short block route ?
Had a friend replace his 1J block with a 2j. He knew someone who got it on employee discount, was ~$1400usd I beleive. Not bad considering what these things are capable of.... thats if you had a 'damaged' motor tho.
I've seen a few local 2jzs with rod bearing knock... problem for them seemed more 'user oriented' to be honest
jasonp1977
Re: 2JZ rebuild Sun, 14 August 2005 04:27 Go to previous messageGo to next message
I priced a new 2J short motor from toyota, was $4K NZ shipped to Aus.
Re: 2JZ rebuild Sun, 14 August 2005 06:18 Go to previous message
A brand new short block sounds great, but I can build a stronger bottom end for less money. I reckon the rebuild option makes more sense.
Previous Topic:hilux 1987 diffs
Next Topic:cryogenic treatments for engines.
Current Time: Fri Nov 20 16:26:00 UTC 2026
Total time taken to generate the page: 0.012638807296753 seconds
