Toymods » Tech & Conversions » 1G part and/or problem
hickoz_bro
1G part and/or problem Wed, 10 August 2005 08:02 Go to next message
rather then starting a new thread everytime i have a question, i'm just gonna keep adding it to this thread...
first on the books is a timing belt idler pulley... can anyone offer help as to what part number? or sizes? where i can get one? anything...
cheers to all..
Re: 1G part and/or problem Wed, 10 August 2005 08:39 Go to previous messageGo to next message
If you mean the bearing?
It should have a part number on it, quote that number to a bearing company.
They should be able to get you a replacement.
Re: 1G part and/or problem Wed, 10 August 2005 12:13 Go to previous messageGo to next message
this is what i collected over time .. (tho i'm sure there's been a thread with this stuff in it before?)
Spark Plugs (require 17mm socket to remove):
ND (NipponDenso) - PQ20R-P8
NGK - BCPR6EP-N-8
Denso K20PRU1
Oil Filter:
Toyota - 15801-44011
Ryco - Z418 (same as ST-185 3S-GTE, 7M-GE, Lexus LS200)
Valvoline - V022 (same as V6 Camry)
Oil (engine):
Mobil 1
Injectors (mine):
Denso (?) 23250-70040 - yellow top, top feed (no barb) ("7F19" on other side from part number)
Ignition:
Toyota (Denso) Coil w/Ignitor 19070-70150 (Denso 101311-4901) EW
which consists of:
Ignitor Assy - Toyota 89620-14420 (Denso 131300-0951) 095
Coil = Toyota 90919-02146 (ND 029700-5551) 12V
Airflow Meter:
Nippondenso 22250-70170 (197100-3320)
Timing Belt:
Toyota 3568 79035 (same as GX81)
Alternator Belt:
Bosch - 4PK 1170
Toyota - 99364-51170
Alternator:
Regulator built in
Toyota 27060-70150
12 V - 1600211-2820
Denso "6G17" (stamped)
Flywheel bolts:
Toyota - 90105-10042 (don't reuse)
Typical Engine Donor models:
1G-Gxx used in - <redacted, search the forum for 'frontcuts'>
Gearbox:
Auto - A340e (4speed ECT)
Asin-Warner (is a BW box made under license)
Model: 30 40LE
Part 35000 - 24161
Gearbox:
Man - W58 (5sp Supra alloy)
Turbo specifications:
model: CT12 (Toyota)
turbine inlet = 25mm
turbine exhaust outlet = 42mm
compressor inlet = 31mm
compressor outlet (to intake manifold) = 29mm
1G Engine Generation identifiers:
Method 1 (ECU/Inj plugs)
gen 1: Yellow ECU plugs and Yellow injectors. 0.50bar / 7psi.
gen 2: Yellow ECU plugs and pale Green injectors. 0.62bar / 9psi
gen 3: Grey ECU plugs and pale Green injectors. 0.75bar / 11psi
Engine ECU:
(Engine Control)
1G-GT Toyota (Denso) 89661-14052 (175000-1140 12V) (sticker: ZV)
connectors: 10pin, 18pin, 24pin
Gearbox ECU:
(Electronic Transmission Control)
1G-GTEU Toyota (Aisin) 89530-24270 (ink stamp: 7F26 - serial number or ROM version?)
connectors: 24pin
[Updated on: Wed, 10 August 2005 13:31]
brett_celicacoupe
townsville NQLD
Re: 1G part and/or problem Wed, 10 August 2005 13:09 Go to previous messageGo to next message
this is the latest stage in my 1ggte RA40 conversion Smile (2 days ago anyway) Wink
BTW: MX62 throttle cable works PERFECT!! Very Happy
http://img66.imageshack.us/img66/9804/ga4000390gf.jpg
http://img66.imageshack.us/img66/9438/ga4000370pg.jpg
Re: 1G part and/or problem Wed, 10 August 2005 13:10 Go to previous messageGo to next message
thechuckster wrote on Wed, 10 August 2005 20:13
t
1G-Gxx used in - MZ11 Soarer
Errr...........
Re: 1G part and/or problem Wed, 10 August 2005 13:28 Go to previous messageGo to next message
CrUZsida wrote on Wed, 10 August 2005 23:10
t
Errr...........
sorry - copy-and-paste from a very old page, written before i knew better Embarassed
fixed
[Updated on: Wed, 10 August 2005 13:29]
hickoz_bro
Re: 1G part and/or problem Thu, 11 August 2005 02:14 Go to previous messageGo to next message
hey guys... cheers for the help so far... me thinks we need compile a 1G bible... lol... all the bits others can contribute...
stay tuned
hickoz_bro
Re: 1G part and/or problem Thu, 18 August 2005 08:07 Go to previous messageGo to next message
okay well the hunt for a idler pulley has (almost) come to an end... managed to source one though none other then toyota themselves, $140 for the little b*tch... dammit! oh well gotta be done.
next i have a query reguarding the location of my fuel pumps. at the moment the surge tank is mounted under the floor behind the left rear tyre, on the left of hte exhaust, yes, it's pretty close, and it's gonna be cosy, the way things are going i'm gonna need to mount the EFI pump behind the surge tank. my concern is that it's gonna get bloody hot under there for the fuel pump, filters, and the fuel itself. my solution is to make a heat shield, but to utilise some heat wrap blanket tape stuff, and fix to the inside of the shield, how i'll figure out later, my questions are:
how hot does it get on the outside of the muffler, typically?
how efficient are the heat wrapping tapes?
what kinda heat can the pumps cope with?
once again, all help is greatly appreciated.
OH... and once again i find myself looking for an igniter, and that brace that crossed between the bottom of the sump, and the bell housing, on the right hand side. it appears that Kristy (FrEaK oF CaRs) has taken the money and run. nearly 3 weeks and still no parts???
[Updated on: Thu, 18 August 2005 08:12]
GTtwin
Newcastle, Australia
August 2005
Re: 1G part and/or problem Thu, 18 August 2005 08:19 Go to previous messageGo to next message
Shocked
WAIT! Hang on to your cash!
I had to replace my tensioner pully in my Soarer. It compleatly ceased, skinning the back off my timing belt and making smoke/bad noise in the process.
A local bearing joint (Bearing Traders) had listings for Cresta/Chaser/Mark II. Being the same as GE and GZE it made it alot easier to find.
Anyway, they sorced me the tensioner and idler for just over $100.
The dude said he got them pretty easy and has had more trouble getting bearings for Commodores.
Anyone who deals with NSK should be able to find them for you.
hickoz_bro
Re: 1G part and/or problem Thu, 18 August 2005 08:22 Go to previous messageGo to next message
shit 'ey... i rang one company here who dealt with NSK, and still came up with squat... so the other cresta/chaser/mark II were aus delivered??? how come they're so easy to a hold of?
hickoz_bro
Re: 1G part and/or problem Thu, 18 August 2005 08:24 Go to previous messageGo to next message
P.S. any part no. to make life a bit easier?
GTtwin
August 2005
Re: 1G part and/or problem Thu, 18 August 2005 09:00 Go to previous message
Not sure why there easy to get, but this dude had a catalouge with all sorts of JDM Toyotas in it. They must be compatible with something Aus delivered, because there was nothing domestic that got any variant of the 1G except 1G-FE in the Altezza (Lexus IS 200), which is totaly different being a narrow angle twin-cam.
I know the idler is the same as whats on my 2S-C powered Corona, but the tensioner is different. The bearing is the same but the tension arm is longer.
Oh, hang on I got them here, still in the original boxes.
Here's the part numbers, (well whats on the boxes).
Tensioner is: NSK 52TB058B05 ENSL 310
Idler is: Koyo TT23000
RF71-12-730A
See if that one gets you outta trouble.
Previous Topic:oil in air intake
Next Topic:budget 4age conversion
Current Time: Wed Nov 18 16:44:33 UTC 2026
Total time taken to generate the page: 0.0066850185394287 seconds
