Toymods » Tech & Conversions » Minor oil seepage from 1g under intercooler pipe
Yeeehah
icon5.gif  Minor oil seepage from 1g under intercooler pipe Thu, 19 December 2002 01:31 Go to next message
Hi all,
My car runs very smooth, but after a cruise i find a bit of oil under the intercooler pipe (cool side) just before it connects back to the main engine pipe. The oil does not leak, its more of a wet oil stain.
Does anyone know what could be the possible cause for this?
Ash
[Updated on: Thu, 19 December 2002 04:12]
cressTT
Re: Minor oil seepage from 1g under intercooler pipe Thu, 19 December 2002 06:12 Go to previous messageGo to next message
my 1G-GTE does that also....I'm not worried because I don't see any white smoke during extendend idling nor hard acceleration.
Remedy
Southern Sydney
Re: Minor oil seepage from 1g under intercooler pipe Thu, 19 December 2002 23:17 Go to previous messageGo to next message
It is common to develop a oil build up inside intercoolers and I'd say this is just leaking out a little.
Flush your intercooler with some kind of thinners to clean this out.
Yeeehah
Ok, so if i see white smoke, what does that mean?
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon1.gif  Re: Minor oil seepage from 1g under intercooler pipe Fri, 20 December 2002 03:37 Go to previous messageGo to next message
Water in your oil.... Sign of something bad, like a blown head gasket...
cressTT
Re: Minor oil seepage from 1g under intercooler pipe Mon, 23 December 2002 03:34 Go to previous messageGo to next message
Remedy wrote on Fri, 20 December 2002 10:17
if it smokes(white) under boost, then the turbos need rebuilding..the oil seals are probably worn...good excuse to do a single turbo conversion Laughing
Yeeehah
Re: Minor oil seepage from 1g under intercooler pipe Thu, 26 December 2002 09:45 Go to previous messageGo to next message
turbo conversion is on the list, but the only thing holding me back at the moment is $$$$
TE72_Turbo
Re: Minor oil seepage from 1g under intercooler pipe Thu, 26 December 2002 12:54 Go to previous message
Where is the breather hose/s from the cam covers go to? Is it connected to the intake pipe before the turbos?
If so, your problem is most likely blow by oil pumping through your intake tract. This is not a huge concern if you still have good compression in all cylinders, some blow by is acceptable, especially with turbo cars. Or of course, as has been mentioned, your turbo's could be stuffed. Crying or Very Sad but they were in really good condition when you bought them this year weren't they?
A fix for the blow-by would be to fit a 'catch can' to the breather pipe/s. This will collect any oil mist rather than cycle it back through your engine.
Phil
Previous Topic:TA22
Next Topic:1986 corona csi and or 22-RE manuals
Current Time: Tue Oct 20 15:53:41 UTC 2026
Total time taken to generate the page: 0.013056039810181 seconds
