Toymods » Tech & Conversions » 3sgte timing belt tensioner
SilverGhost
3sgte timing belt tensioner Wed, 10 August 2005 09:21 Go to next message
Hi All,
Just a quick question about this part, when replacing it, do I have to compress the pin back into the tensioner at all to get clearance, or will it just pop back in. If anyone has replaced these on a 3s let me know whats the best way to do it.
Many thanks Smile
Joshstix
Toymods Vice President
Re: 3sgte timing belt tensioner Wed, 10 August 2005 09:35 Go to previous messageGo to next message
You need to compress the tensioner in a vice then use a 1.25mm allen key to put through the hole drilled in the tensioner body and the tensioner rod. Once you have the tensioner located correctly and bolted up to the engine you can then remove the allen key from the hole and the tensioner will operate as normal.
If you are able to push the rod in without a hell of a lot of effort, like using your body weight to push it against a concrete floor, then you should replace the tensioner.
off-road
Alice Springs
Re: 3sgte timing belt tensioner Wed, 10 August 2005 09:36 Go to previous messageGo to next message
Place tensioner in vice and very slowly compress pin back into tensioner until hole in pin and hole in housing line up.Put small allen key or drill bit in hole.Refit tensioner to motor and when every thing is lined up pull out allen key or drill bit.
SilverGhost
Re: 3sgte timing belt tensioner Wed, 10 August 2005 09:41 Go to previous message
thanks heaps guys, yeah it was replaced about 12 months ago, body weight is definitely not enough to compress it.
I spotted those holes as well, and was pretty sure id have to compress it somehow, but wasnt sure of the best way.
cheers Cool
Previous Topic:Kouki/Zenki Trueno Body/light Interchangability
Next Topic:gearbox capacity( liters for oil) for a sx
Current Time: Sat Oct 24 23:07:19 UTC 2026
Total time taken to generate the page: 0.012727022171021 seconds
