Toymods » Tech & Conversions » TRD head gasket
corbet01
April 2005
TRD head gasket Thu, 11 August 2005 12:31 Go to next message
I have a 100kw small port and will be doing some head work in the near future. Can i use a 0.8 or 0.5 TRD head gasket or will this raise the compression to much. It has 10.3 at the moment. What kind of kw increase could i expect.
Big T
Re: TRD head gasket Thu, 11 August 2005 13:26 Go to previous messageGo to next message
If you're using a metal hg, you'll need to deck the block/head. Find out how much is shaved off and work out what the resulting comp ratio from the machining is and use that to work out the thickness of hg you should be using.
If this makes no sense to you, pay someone to do it for you.
Eddie.
Sam_Q
S.E suberbs, Vic
Re: TRD head gasket Fri, 12 August 2005 06:45 Go to previous messageGo to next message
I have been told many people havent decked the block with a metal HG and have had no problems
Re: TRD head gasket Fri, 12 August 2005 07:12 Go to previous message
Sam_Q wrote on Fri, 12 August 2005 16:45
but that doesn't make it a good idea Razz
decking.shavign ensures a good surface to begin with.. better than having to dissasseble the motor later when the HG doesn't seal... think of it as 1% work now to stop 100% work in future
Previous Topic:VN V6 into RA28????? Possible?
Next Topic:canberra exhaust shop
Current Time: Fri Nov 20 21:10:29 UTC 2026
Total time taken to generate the page: 0.0051710605621338 seconds
