Toymods » Tech & Conversions » Significant performance drop when warm - 1G
VeeP
May 2005
Significant performance drop when warm - 1G Fri, 12 August 2005 02:36 Go to next message
Hey everyone,
when the coolant mark is below "normal" (the middle bar) on my soarer, it goes well. But once the coolant goes up the middle mark, the performance drops significantly. What could this be?
Also, why does it backfire? How do i make it stop?
Merudo
Central Coast, NSW
February 2005
Re: Significant performance drop when warm - 1G Fri, 12 August 2005 03:51 Go to previous messageGo to next message
This is amazing!
This is exactly the same problem that I have.
From your description, this is precisely the problem I am encountering...
Merudo
Central Coast, NSW
February 2005
Re: Significant performance drop when warm - 1G Fri, 12 August 2005 05:07 Go to previous messageGo to next message
Hey mate, check out the last page of the soarer thread. We're talking about my problem there and brainstorming some possible solutions, and things that should be checked etc Wink
PS: Soarer thread is in general car talk
VeeP
May 2005
Re: Significant performance drop when warm - 1G Mon, 15 August 2005 15:45 Go to previous messageGo to next message
man, this is still happening. . .
wtf?
HyDrA
Adelaide, SA
Re: Significant performance drop when warm - 1G Mon, 15 August 2005 23:59 Go to previous messageGo to next message
Have you replaced the temp sensor (not the gauge one...)?
Almost sounds like the car is in limp mode.
Merudo
Central Coast, NSW
February 2005
Re: Significant performance drop when warm - 1G Tue, 16 August 2005 00:02 Go to previous messageGo to next message
i pulled a code for the coolant temp sensor once
however resetting the ECU, i did not pull that code again.
I do however constantly get the "A/C is on or transmission is in gear" error code, when the transmission is in park and the air con is off. Happens in any gear with the transmission.
by the way, after resetting the ecu, i still have the performance problem after its warmed up, yet yeah, i dont pull the coolant temp sensor code anymore.
*shrugs*
VeeP
May 2005
Re: Significant performance drop when warm - 1G Tue, 16 August 2005 01:32 Go to previous messageGo to next message
i havent had the coolant temp sensor code come up ever.
How much is it to replace the coolant temp sensor, and where is it located in the engine?
stradlater
Arthurs Creek, Victoria
Re: Significant performance drop when warm - 1G Tue, 16 August 2005 01:59 Go to previous messageGo to next message
The temperature sensors are near the thermostat at the front of the engine. There's two, one for the gauge and the other for the ecu.
The one for the guage is the on that is on the FRONT of the engine.
The one that is for the ecu is on the SIDE of the engine, under the thermostat near the dizzy.
No idea on how much to replace, I use only quality holden parts.. Wink
Re: Significant performance drop when warm - 1G Tue, 16 August 2005 02:01 Go to previous messageGo to next message
stradlater wrote on Tue, 16 August 2005 09:59
3 actually, there is another one near the ECU one for the CSI.
Re: Significant performance drop when warm - 1G Tue, 16 August 2005 03:30 Go to previous message
Test the watertemp sensor before replacing
http://www.cygnusx1.net/supra/library/TSRM/fi/FI_1 13.gif
Merudo, check that your TPS is in IDL too.
http://www.cygnusx1.net/supra/library/TSRM/fi/FI_1 01.gif
Initial conditions to check codes
http://www.cygnusx1.net/supra/library/TSRM/fi/FI_0 23.gif
Previous Topic:headgasket leaking? or?
Next Topic:TA23 and RA23's
Current Time: Sat Oct 31 14:43:28 UTC 2026
Total time taken to generate the page: 0.16071009635925 seconds
