Toymods » Tech & Conversions » Radio Electric Antenna trouble
wagonist
Toymods Club Treasurer
Radio Electric Antenna trouble Fri, 12 August 2005 08:45 Go to next message
The electric antenna on my Caldina sounds like it wants to keep on going up even at full extension.
It stops pushing upto 5 seconds after the antenna is fully extended.
It is the factory Toyota unit & I'm not going to replace it with a fixed one despite possibly finding a serious buyer for it.
Any helpful suggestions welcome.
STR8 2.8
Re: Radio Electric Antenna trouble Fri, 12 August 2005 08:52 Go to previous messageGo to next message
yes my old supra did this too, i just assumed it was normal...
wagonist
Re: Radio Electric Antenna trouble Fri, 12 August 2005 09:06 Go to previous messageGo to next message
Mine's only started doing it the last 2 weeks.
Toobs
Re: Radio Electric Antenna trouble Sat, 13 August 2005 00:42 Go to previous messageGo to next message
You've probably lost a few teeth on the mast's ribbon, mine was like this for ages... it would go up to what I thought was normal height and just keep making a clicking sound.
Upon removing the mast (very easy to do) I discovered that the cable had snapped right down the bottom.
To remove the whole mast:
turn acc on to get the antenna to go up.
unscrew the silver locking cap
turn acc off to make the antenna go down.
then turn the acc on to make the antenna go up and bundy around to the antenna while its still going up and pull it to make the mast come out.
I bought an original toyota mast to replace mine at about $40-50 from memory... you can buy cheaper Airpro (sp?) ones for most models from repco, autobarn etc. for about $20
Toobs
Re: Radio Electric Antenna trouble Sat, 13 August 2005 00:43 Go to previous messageGo to next message
PS in my case because the cable had snapped I had to disassemble the whole motor... if yours just started and it always goes up and down by itself it probably hasn't snapped yet.
wagonist
Re: Radio Electric Antenna trouble Sat, 13 August 2005 00:59 Go to previous messageGo to next message
Cheers Toobs, I thought it may have been something as simple as that because its not trying to over-extend by the same amount each time.
Time to visit Mr Toyota....
I hope it's only $50, Subaru Liberty ones are about $80-$90 Shocked
wagonist
Re: Radio Electric Antenna trouble Sat, 13 August 2005 03:22 Go to previous message
Toobs wrote on Sat, 13 August 2005 10:42
Bundy around it? What do you mean by that?
Previous Topic:MA70 Dash into SA63
Next Topic:pod filter for 3sge
Current Time: Mon Nov 23 03:38:59 UTC 2026
Total time taken to generate the page: 0.0041449069976807 seconds
