Toymods » Tech & Conversions » 4AGE missing when throttle very slightly open.
Scorpion
Menai area of Sydney
4AGE missing when throttle very slightly open. Fri, 12 August 2005 09:24 Go to next message
Hi All,
Has anyone had the problem with a 4AGE where you are cruising along nicely with almost no throttle at all but as you just open up to accelerate, the engine seems to stutter then comes on really strong after the revs are up ? It's like it's getting too much air on slight throttle but open it further and it goes better.
I can't decide whether it is fuel or ignition and the fuel filter should be OK as it goes well at high revs.
I've adjusted the TPS pretty precisely to the manual specs.
I'm thinking it may be an injector issue (although they were cleaned less than 500kms ago)as it seems to lean off according to the O2 sensor and when I have the 8k resistor across the air temp sensor to richen the mixture, the problem seems less but it may be being masked by the engine performing a bit stronger.
It's not the hunting of the TPS that you get when it's out of adjustment - I can induce that and rectify it pretty easily.
No ECU error code which is why I'm thinking something at the end of the EFI chain like injector feed or spark. If it's spark that's missing I'd expect the mixture to richen up during the problem as there would be unburned fuel going through.
Apologies for the long winded info but it would be great if someone else has had a similar problem ... and fixed it.
Thanks.
TopSecret72
Wollongong
January 2005
Re: 4AGE missing when throttle very slightly open. Thu, 18 August 2005 00:18 Go to previous messageGo to next message
Has anyone got a solution to this problem? Because i'm having the exact same problem with my 4AGE and can't work it out.
Lachie
Re: 4AGE missing when throttle very slightly open. Thu, 18 August 2005 03:13 Go to previous messageGo to next message
Have you guys removed the intake resonators?
There's an article in Zoom magizine that my mate was telling me about that proves that intake resonator can imporve midrange torque and Kw's
No idea if it helps, just a thought
Re: 4AGE missing when throttle very slightly open. Thu, 18 August 2005 03:20 Go to previous messageGo to next message
have you actually checked the TPS position with the correct feeler guages?
If not - DO IT.
adamb131
Re: 4AGE missing when throttle very slightly open. Thu, 18 August 2005 07:54 Go to previous messageGo to next message
Similar prob for me turned out to be the AFM after it eventually progressed from what you are describing to engine barely running over idle... if you got AFM that is!
skellator
Coffs Harbour, NSW
Re: 4AGE missing when throttle very slightly open. Thu, 18 August 2005 09:33 Go to previous messageGo to next message
i have a similar (if not the same) problem atm
ive just had a new engine installed (previous one seized), and when you floor it suddenly, it kind of stutters/jerks. i havent been game enough to keep flooring it after that though.
anyway, i took it into the mechanic's the other day because the check engine light was coming on and i thought it was because of low level/pressure power steering fluid as it was leaking, but he found that the oxygen sensor had a frayed wire or something like that. im taking it in again tomorrow morning so he can put the oxy sensor from my old engine on there, so ill get back to you guys on whether it works or not
187_20v
Re: 4AGE missing when throttle very slightly open. Thu, 18 August 2005 18:34 Go to previous messageGo to next message
yeh i have the same problem with my 20v
but it only does it every now and then
but specially at the lights when im idleing for too long
its use 2 do it heaps more before i fixed my AFM and changed the air filter
skellator
Coffs Harbour, NSW
Re: 4AGE missing when throttle very slightly open. Fri, 19 August 2005 08:13 Go to previous messageGo to next message
skellator wrote on Thu, 18 August 2005 19:33
it worked Very Happy all good now
Scorpion
Re: 4AGE missing when throttle very slightly open. Fri, 19 August 2005 08:33 Go to previous messageGo to next message
Hmmm, thanks for the info.
I have tried removing the air filter without luck but have a spare MAP sensor so I might try swapping that over. Cheers.
TopSecret72
Wollongong
January 2005
Re: 4AGE missing when throttle very slightly open. Fri, 19 August 2005 11:38 Go to previous messageGo to next message
Well re-adjusting the TPS made a massive difference but it's still sort of there when you take off after stopping at a set of lights or something.
[Updated on: Fri, 19 August 2005 11:39]
Scorpion
Re: 4AGE missing when throttle very slightly open. Sun, 04 September 2005 11:04 Go to previous message
I made up an adaptor to plug into the TPS and check it out for voltages and resistance. While I have the feeler gauge settings set up properly, it looks like the guts of it may be stuffed. As you open the throttle, the resistance between VTA and E2 should increase while the resistance between VTA and Vcc should decrease. ( E2 to Vcc is a resistor with VTA sweeping from one end of it to the other ) Mine likes to go open circuit. I may be able to try a spare 1G TPS tomorrow night. Will advise if this fixes it.
Previous Topic:ae92 temp gauge not workin
Next Topic:wiper wiring question
Current Time: Tue Oct 20 23:53:11 UTC 2026
Total time taken to generate the page: 0.051592111587524 seconds
