Toymods » Tech & Conversions » 18RG block with unknown Pistons(with close up pics)
wolverine
18RG block with unknown Pistons(with close up pics) Fri, 12 August 2005 10:20 Go to next message
hey can anyone help me identify this pistons
its on the block that i found
it looks good
but dont know what else done to the block
is these a hi compression ones???
is it forged???
i'll get a more close up pics soon
thanx
http://img358.imageshack.us/my.php?image=imgp03729 uq.jpg
http://img358.imageshack.us/img358/5882/imgp03729u q.jpg
[Updated on: Mon, 22 August 2005 11:24]
munki
Gold Coast
Re: 18RG block with unknown Pistons Fri, 12 August 2005 11:30 Go to previous messageGo to next message
they look like std 9.7:1
Daniel
bbaacchhyy
Re: 18RG block with unknown Pistons Fri, 12 August 2005 11:43 Go to previous messageGo to next message
munki wrote on Fri, 12 August 2005 21:00
Daniel
I reckon they are higher than that. From memory (it is pretty hazy I admit, but the 9.7:1's had a much flatter top section.
I would guess that they are more like 11.5 or 12:1
What is the history of the engine ?
Clean the top of the piston and if possible measure the height from the deck.
Michael B
wolverine
Re: 18RG block with unknown Pistons Fri, 12 August 2005 11:58 Go to previous messageGo to next message
i cant actually source the history coz i got it as a spare
with the working 18RG that i have
the guy i got it off reckons its from his mate and dont remeber what happened
it looks like the piston hit the valve somehow and broke it
it did came as is with the head sitting on top with a broken valve and 2 bent valves
no head bolts
no chains
no manifolds
but yeah the top of the pistons is not flat at all
i'll try to get some measurements and clearer pics
what am i looking for the measurements to know which one it is?
so its either 11.1 or 12.1 ????
thanx
earlyrolla
Re: 18RG block with unknown Pistons Fri, 12 August 2005 12:33 Go to previous messageGo to next message
Unless someone can identify the brand of piston I think it will be a stab in the dark at the exact compression ratio.
If you really want to know then work it out the hard way...
You can always take a mould of the top of the piston then work out how much water it takes to fill the mould (use a syringe). At the same time determine the volume of the combustion chamber in the head (anyone know this already?) using the water method too. Head combustion chamber volume - piston top volume = actual combustion volume. Next work out the volume of the cylinder (pi x radius_of_cylinder^2 x (stroke + head_gasket_thickness)). Then divide the cylinder volume plus the actual combustion volume by the actual cylinder volume and you have the static compression ratio.
Or just get all your numbers and use one of these things:
http://www.turbofast.com.au/Tfcomp.html
http://www.rbracing-rsr.com/compstaticcalc.html
Re: 18RG block with unknown Pistons Sat, 13 August 2005 05:13 Go to previous messageGo to next message
combust chamber volume = 72mL IIRC
Mr DOHC
Re: 18RG block with unknown Pistons Sat, 13 August 2005 07:06 Go to previous messageGo to next message
they look like my HKS 12.5 to one, but BIGGER
contact Steve M, he has a set of Arias 12.5:1's too
Steve M
Re: 18RG block with unknown Pistons Sun, 14 August 2005 01:09 Go to previous messageGo to next message
Are they forged? Only one way to tell for sure, show us a photo from the bottom of the piston.
If you can get a direct side on shot of the domes that might help.
If you could post the dome height and bore size that could help too.
The amount of flat between the valve cut-outs is slightly skinnier than the Arias 12.5s.
The sides of the dome are steeper and more square in shape than the Arias ones.
All I can guess is that they are definately not of lower compression than the Arias 12.5:1s unless their bore is smaller than 92mm.
The depth of the valve cut outs doesn't look like the reason that valves were damaged. They appear plenty deep enough.
Most likely the valves were hitting each other, the valve cutouts were on the wrong angle or there was a timing issue.
What are the cams that came with the engine, got any pics?
If Toyota cams, is there a number stamped into the cam on the flat that the cam timing cog goes onto? If so, what is the number?
Also what are the valve sizes?
If they are TRD ones, I may be able to source some new ones for you through an upcoming Toysport Order.
wolverine
Re: 18RG block with unknown Pistons Mon, 22 August 2005 10:08 Go to previous messageGo to next message
<a href="http://img370.imageshack.us/my.php?image=img00548i l.jpg" target="_blank"><img src="http://img370.imageshack.us/img370/2328/img00548il .th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img370.imageshack.us/my.php?image=img00557r h.jpg" target="_blank"><img src="http://img370.imageshack.us/img370/8084/img00557rh .th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
<a href="http://img370.imageshack.us/my.php?image=img00560f y.jpg" target="_blank"><img src="http://img370.imageshack.us/img370/9886/img00560fy .th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
ok here a close up and a better pic
i just wanna know if its ok to use this block on EFI with high compression piston??
im planning to use this block after i sent it to the shop
Mr DOHC
Re: 18RG block with unknown Pistons Mon, 22 August 2005 11:35 Go to previous messageGo to next message
the block is ok to use, these are very high compression race pistons, not a road going item
i'm more worried about the shitload of metal filings everywhere
what u doing with the pistons
wolverine
Re: 18RG block with unknown Pistons(with close up pics) Mon, 22 August 2005 11:48 Go to previous messageGo to next message
yeah its just a bit of dust and shit
i havent done anything with the pistons
but its notmaly covered up
im planning to use the whole thing and put my EFI on it
just wondering if i can do that due to high compression piston
everything is good but i might need to pull everything apart but havent got the time and motivation
but yeah hook me up with those gasket of yours please MR DOHC
Mr DOHC
Re: 18RG block with unknown Pistons(with close up pics) Mon, 22 August 2005 12:01 Go to previous messageGo to next message
bolting up the efi will be no worries, but running naything but a stock 18RG and the stock computer shits itself
so a fully programable comp will be needed
wolverine
Re: 18RG block with unknown Pistons(with close up pics) Mon, 22 August 2005 12:09 Go to previous messageGo to next message
i have a link computer fuel only
what will happen if u just use the one i have now?????
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: 18RG block with unknown Pistons(with close up pics) Mon, 22 August 2005 22:42 Go to previous messageGo to next message
I suspect that they are the TRD 2 ring Forged pistons. I had a set of these many years ago. Most of the after market pistons for these engines had all the machined faces flat. These have rounded sides.
wolverine
Re: 18RG block with unknown Pistons(with close up pics) Thu, 25 August 2005 07:51 Go to previous messageGo to next message
andrewvibert wrote on Tue, 23 August 2005 08:42
tell me more
did you get to put it on
how did it go
yeah
i have a link computer from new zealand that controls fuel only
how will it go if i use this computer with this pistons???
YelloRolla
On your mum!
Re: 18RG block with unknown Pistons(with close up pics) Thu, 25 August 2005 10:11 Go to previous messageGo to next message
Running your EFI cams will almost certainly not be a good idea. High comp requires cams with more overlap and greater duration.
If you try to run these bigger comp pistons with std cams your cylinder pressures will most likely become too great.
wolverine
Re: 18RG block with unknown Pistons(with close up pics) Thu, 25 August 2005 20:28 Go to previous messageGo to next message
i have 253 heads and 250
can i use thier cam instead of 270?????
Steve M
Re: 18RG block with unknown Pistons(with close up pics) Fri, 26 August 2005 08:22 Go to previous message
88250 stamped cams would definately be more suited to these pistons. 88231 or earlier would also be better than 88251 or later.
With the compresion that you have, the issue is fuel type. Using 98ron fuel, you'd probably have to have 310 degree or more cams, just to lose the compression.
The 12.5:1 compression pistons I've got were used with methanol and mechanical injection in a sprint car.
The only TRD pistons I've seen had "dome" shaped tops on them, as do the Arias 12.5s. I've never seen 18RG pistons that have such square sides as yours, they must get quite close to the sides of teh conbustion chamber. I've only seen forged ones that have more of a tennis ball shape dome.
JP engineering in SA make some that are squarer, I think, I've not seen them in a while, but they are cast.
If you are able to measure the volume (accounting for valve pit volume below block height) we should ba able to help you out with a rough compression ratio.
Previous Topic:Project ST162 - Take 2
Next Topic:Koni's on MA61
Current Time: Thu Nov 19 06:07:59 UTC 2026
Total time taken to generate the page: 0.012778997421265 seconds
