Toymods » Tech & Conversions » auto 3sgte info wanted
crusty
bris
August 2005
auto 3sgte info wanted Fri, 12 August 2005 12:36 Go to next message
hey peoples any one know if a v6 camry box would fit into a st162 and would it handle the power of a 3sgte?.
saveing up to do a swap from the 3sfe piece and want to keep the ease of a auto box. if any one has a suugestion\idea about a better choice apart from going to manual i would apreciate it a heck of a lot.
thanks for the help
chris
bahnugget
Brisbane, QLD
August 2005
Re: auto 3sgte info wanted Sat, 13 August 2005 03:05 Go to previous messageGo to next message
better choice = lose auto box Wink
far as i've been able to pick up from reading around the place, V6 Camry boxes are hard to come by, and you gotta modify them a little to get em fitted. may be different for an auto tho? Confused
[Updated on: Sat, 13 August 2005 03:06]
Meat_rack
East Maitland NSW
Re: auto 3sgte info wanted Sat, 13 August 2005 05:20 Go to previous messageGo to next message
Woops
[Updated on: Sat, 13 August 2005 05:21]
Meat_rack
East Maitland NSW
Re: auto 3sgte info wanted Sat, 13 August 2005 05:21 Go to previous messageGo to next message
No it wont bolt up. All FWD toyota boxes are basically the same internally so yes it will be able to take the power. Most auto boxes can take power its just how hard you drive them.
So yes it will take the power but the problem it it wont bolt up to the motor..
Andrew..
berad
Re: auto 3sgte info wanted Sat, 13 August 2005 05:47 Go to previous messageGo to next message
auto will kill the power anyway... buy the 5 sped sv21 box or mr2 box
crusty
bris
August 2005
Re: auto 3sgte info wanted Tue, 16 August 2005 07:20 Go to previous messageGo to next message
i live in the city and like not haveing to change gears. manuals dont like my driveing so am not to keen on them. any idea if a worked box might do. willing to spend extra on torque converter and internals when the swap is nearer. my cuss has a st162 3sgte with a manual and want to beat him useing a auto.
thanks for the help guys
chris
bahnugget
Brisbane, QLD
August 2005
Re: auto 3sgte info wanted Tue, 16 August 2005 07:25 Go to previous messageGo to next message
crusty wrote on Tue, 16 August 2005 17:20
if you cant handle a manual gearbox you're going to spend ALOT more money for something thats not as good. problem with auto's is they suck.
in the end its ur choice, as for will the worked box do, if you work anything enough it'll do, its all a matter of how deep ur pocket is.
[Updated on: Tue, 16 August 2005 07:26]
terra
July 2005
Re: auto 3sgte info wanted Tue, 16 August 2005 08:15 Go to previous messageGo to next message
the problem i see with the auto isnt mechanical, wouldnt me too hard to bolt it up
but more electical -- what the hell are you going to run to control that auto?
it wont fit space wise anyway me thinks -- the A541E/+/newer autos are HUGE
sideshow
Re: auto 3sgte info wanted Tue, 16 August 2005 12:29 Go to previous messageGo to next message
i have played with a 3sge with an auto
the autos run a seperate ecu for them
it needs to be wired up but first u need to find the ecu i have only seen one and it was in a car
FASTFOO
melb
February 2005
Re: auto 3sgte info wanted Tue, 16 August 2005 12:38 Go to previous message
V6 auto will bolt up (s,vz,mz bolt patens are all the same Shocked )
but you may have issues with mounts, the other thing is they are electronic controlled and a 3sgt computer has not got any control for it.
What we have done on the few we have made auto is use a SV21 non electronic auto, it fits easy and works well (a little slower off the line but awsum as it holds boost through gear changes).
As far as strength we have done 4 of these in the last 4 years and had 1 auto blow up and it was a little sus to start with.
Do it it's good. Wink
Regards.
MATT.
Previous Topic:mr2 ferrrari style bodykit
Next Topic:Bleeding brakes
Current Time: Tue Oct 27 17:00:27 UTC 2026
Total time taken to generate the page: 0.0093529224395752 seconds
