Toymods » Tech & Conversions » Whats wrong with Whitchy's car now????
WHITCHY
Castle Hill
Whats wrong with Whitchy's car now???? Fri, 12 August 2005 13:23 Go to next message
Just about to drive into my street, and the engine cut out, just figured it wasn't warm enough yet, started her back up and away she went.
Pulled up to my driveway and she cut out again, this time not so much luck starting!
Sat for a little and then tried it again, got it going, it won't idle at all, revs are very irratic, tried to reverse up my driveway but it couldn't even make enough power?
Drove down the street couldn't rev past 3k, got a run up and just made it up my driveway, she cut out and I let her roll back into the garage, only to turn the light on and see smoke coming from under her?
Looked underneath and my cat was glowing red!
Can someone please tell me what the hell is wrong with my engine now?
It just manages to start, it backfires, sounds like shit, won't idle unless I have my foot on the accelerator and even then its a very crazy idle, it won't rev past 3k, can't even make enough power to reverse up my driveway and my cat is glowing!
PLEASE HELP ME!!!
Thanks to anyone that can offer advice and help!
Cheers.
-Whitchy-
rob_RA40
c'town, NSW
Re: Whats wrong with Whitchy's car now???? Fri, 12 August 2005 13:25 Go to previous messageGo to next message
cat shat itself maybe, core has collapsed/melted blocking zorst gasses from passing thru.
WHITCHY
Castle Hill
Re: Whats wrong with Whitchy's car now???? Fri, 12 August 2005 13:30 Go to previous messageGo to next message
But it's only a 3 month old cat?????
Dale_ta22
Forster NSW
Re: Whats wrong with Whitchy's car now???? Fri, 12 August 2005 13:31 Go to previous messageGo to next message
rob_RA40 wrote on Fri, 12 August 2005 23:25
cat p00ed itself maybe, core has collapsed/melted blocking zorst gasses from passing thru.
Quick correction Razz
rob_RA40
c'town, NSW
Re: Whats wrong with Whitchy's car now???? Fri, 12 August 2005 13:33 Go to previous messageGo to next message
lol of course what was i thinking cheers Wink
Re: Whats wrong with Whitchy's car now???? Sat, 13 August 2005 05:09 Go to previous messageGo to next message
there's a banana in the tailpipe?
cams_ae86
Re: Whats wrong with Whitchy's car now???? Sat, 13 August 2005 05:17 Go to previous messageGo to next message
where can i get one of these bananas for my tailpipe Wink
nick2b
Re: Whats wrong with Whitchy's car now???? Sat, 13 August 2005 05:24 Go to previous messageGo to next message
Maybe your fuel filter clogged up, d/c your fuel filter and and conect both fuel lines with a clamp start it if it runs well again you know what the problem was.
ae86drift
sydney.au
Re: Whats wrong with Whitchy's car now???? Sat, 13 August 2005 05:25 Go to previous messageGo to next message
take the cat out, youve killed it... again
even one afterburn of fuel into the exhaust can fuck a cat up pretty easily Sad
id bee looking at tuning your engine to not run so rich if i were you.
Re: Whats wrong with Whitchy's car now???? Sat, 13 August 2005 05:29 Go to previous messageGo to next message
best option is probably a multi fit cstom HKS banana.. they come with stickers...
glowing cat = blocked... are you runnign rich??? rich + cat = melted cat = blocked = glowing..
pull the fucker off and have a look thru.... it's rooted....
check mixtures without cat, and then replace with new cat...
WHITCHY
Castle Hill
Re: Whats wrong with Whitchy's car now???? Sat, 13 August 2005 09:56 Go to previous messageGo to next message
Thanks for all the help! The bananna has been removed!
The farken ECU decided to fuck out, tried the spare and its all good now!
Is there any way that I can now check if I did any damage to my cat? I can't really just bolt it off, cause the guy who did my exhaust was a lazy bastard and only put a flange at the end of the extractors. Will I just take the fact that its running normal again a good sign that no damage was done?
Thanks again for the help.
Cheers.
-Whitchy-
Re: Whats wrong with Whitchy's car now???? Sat, 13 August 2005 13:36 Go to previous message
you still haven't addressed the problem of the cat that's most likely melted
"rich + cat = melted cat = blocked = glowing"
take to proper exhaust shop, get 2nd flange fitted, replace cat if stuffed.
Previous Topic:Weber Manuals- which is better?
Next Topic:troubles wiring up 100kw conversion
Current Time: Sat Oct 17 21:30:13 UTC 2026
Total time taken to generate the page: 0.0053141117095947 seconds
