Toymods » Tech & Conversions » 1g-gze/1g-gte into hiluz
Richrider
July 2005
1g-gze/1g-gte into hiluz Sat, 13 August 2005 01:39 Go to next message
Hi guys.Just looking for some info on the 1g engines into a 93 RN85 hiluz fitted with at the moment a 22r and 5 speed.
Just looking for some advise on fitting this engine.
1 engine mounts?
2 sump mods and clearence mods to /firewall/steering/swaybar needed?
3 will the 1st gen 1g-gte intercooler fit under the hood and does anyone have a spare one if it fits if I get a gen 2/3?
Not wanting to run a front mount
4 getting the 1g-gze past engineering/emissions is not a problem in Vic but what about getting 1g-gze supercharged passed?
5 bellhousing for the 1g to my manual,what to use? flywheel? clutch? or is it just easer to keep the auto with the 1g when I do the swap and can I use the standard tailshaft?
6 in line high pressure fuel pump ok?
Thanks Rich
[Updated on: Sat, 13 August 2005 01:44]
Richrider
July 2005
Re: 1g-gze/1g-gte into hiluz Sat, 13 August 2005 23:52 Go to previous messageGo to next message
Anyone help me???????
Allan
Re: 1g-gze/1g-gte into hiluz Sun, 14 August 2005 00:59 Go to previous messageGo to next message
a 1g will suck! (a 1g-gze slightly less suckage) you need something with TORQUE for a commercial
Richrider
July 2005
Re: 1g-gze/1g-gte into hiluz Sun, 14 August 2005 04:04 Go to previous messageGo to next message
I am only interested in the supercharged or turbo version of the motor as above, the 1g-gze (supercharged) or 1g-gze (turbo)
Not interested in the 1g-ge.
Rich
VeeP
May 2005
Re: 1g-gze/1g-gte into hiluz Sun, 14 August 2005 15:51 Go to previous messageGo to next message
its a 2L motor d00d,
its got minimal bottom end in any form.
Ur better off getting a larger capacity motor
TheStitt
Membership Secretary
Re: 1g-gze/1g-gte into hiluz Sun, 14 August 2005 23:02 Go to previous messageGo to next message
Knackers a guy on the forums a while ago had a 1GGTE Lux. It went alright I think a 13 or 14 sec 1/4 mile. He doesn't post anymore but you could search for him in members, than show all his posts. Hopefully some of your question will of already been asked by him.
He didn't have any firewall mods and atleast engine mounts where custom.
I'm not sure what box your lux came with but I would be putting a W58 at least behind if you wanted to stay manual.
You may have to look at changing the diff ratio to to suit the engine.
Higher pressure pump in line should do the trick no real worries.
Richrider
July 2005
Re: 1g-gze/1g-gte into hiluz Mon, 15 August 2005 08:10 Go to previous messageGo to next message
My ute has the G52 gearbox in it. Am happy to go for a auto with this converson as I have stuffed knees so I will most likely have to drive autos as my daily driver(as this ute is) from now on and keep the manuals for the weekend.
I was hoping to find someone here that has done this before for advise.
As with the power,a standard 1g-gze has nearly twice the power and 1/2 as much torque again as my 22r and should use only 50% of the fuel it is using now!
My ute only weighs 1320kg.
So I think this motor should be a easy fit, cheap to buy and fit.A lot easer than a 1uz-fe
sideshow
Re: 1g-gze/1g-gte into hiluz Mon, 15 August 2005 09:27 Go to previous messageGo to next message
a 1ggze is good off the mark
a 1ggte with abit more boost is similar to a 1uz
all in hiluxes
if u go auto u might need an auto ecu too be wired up to the gbox aswell
this is a bigger job than wiring the engine ecu
i can wire up yr looms and send them back to u with only afew wires to connect
even my hilux with a 1uz isnt that fast
its just like a v8 commodore maybe bit better
anything u do wont be super fast unless u get a 1jz and boost it up
but for a work ute with good torque a 1uz is good but will cost more
for a little bit more grunt the 1ggze is good and is the easiest to fit as the gte hits the master cyl or brake bnooster
then u have to worry bout intercooler plumbing
the gze fits in with the most minimal mods
then its easy to fit bigger brakes if your engineer wants them
engine mounts have to be custom made for 1gg and 1uz
if u run std ecu emissions should not be a prob
1gg should bolt to a common toyota gbox
i can find out my friend just did a 1ggze into a hilux
anyway u go it will still cost over 4000 by time u finish
andrewvibert
Forum Sponsor
Shepparton (Vic)
Re: 1g-gze/1g-gte into hiluz Tue, 16 August 2005 06:21 Go to previous messageGo to next message
I have a 1ggte auto 1/2 cut at the moment. (GA70) . A 2 wd hilux goes well with this conversion. I have had a couple of customers do 1ggze conversions on gas and they were both disapointed. . I have owned a GA70 in man as a standard car and they go quite well. (obviously not as well as a 2.5 or 3 l turbo). A supra is not a light car. The auto trans works well with the turbos for smooth no lag power.If you want man then the box in the ute will be fine. I can supply flywheel and bellhousing to bolt it up. If you want further info then e mail me.
[Updated on: Tue, 16 August 2005 06:23]
Richrider
July 2005
Re: 1g-gze/1g-gte into hiluz Tue, 16 August 2005 09:32 Go to previous messageGo to next message
If I use the auto gearbox that comes with the 1/2 cut and use all the parts that are fitted to the donor car I should have no prob??? Right?
I should be ok with the brakes as the ute is a RN85 (Full 1 tonner) with the larger brakes.
sideshow
Re: 1g-gze/1g-gte into hiluz Tue, 16 August 2005 23:28 Go to previous message
ask yr engineer about brakes and emissions
not sure bout melb rules
but when i got my hilux ready
one engineer wanted emissions test and bigger brakes
the other engineer wanted no emissions and std brakes
not hard to decide which one to go with
but in the end i did fit bigger brakes which need to be engineered still
Previous Topic:Corona RT142 IRS in ST141
Next Topic:4agze blowing igniters
Current Time: Thu Nov 19 07:46:24 UTC 2026
Total time taken to generate the page: 0.01147198677063 seconds
