Toymods » Tech & Conversions » TA22 rear window winder operation
gpvm
TA22 rear window winder operation Sun, 14 August 2005 09:33 Go to next message
I'm trying to fix up my side windows. Both rear windows have a lot of play when they are wound to the half way up position. By "play" I mean the windows rotate about 30 degrees around their forward bottom corners. Should the windows have so much play at this point? Do these windows rely on the rubber seals under the roof edging to guide them into the proper final position? If so, I will have to hurry up and replace them before I do more work on the winders! Cheers ... Greg
Royboy
April 2005
Re: TA22 rear window winder operation Sun, 14 August 2005 10:00 Go to previous messageGo to next message
The rear windows have a plate with two plastic grommet that guide the window up and down. They should be pretty much fixed.
I have replace mine. It's not easy but well worth it. Somebody else on the forum told me to go out and buy shower door rollers, the ball bearing type.
You drill out the log and bolt in the rollers, they are a perfect fit in the track. I put new grease in the track and they work a treat.
Good Luck.
[Updated on: Sun, 14 August 2005 10:03]
Royboy
April 2005
Re: TA22 rear window winder operation Sun, 14 August 2005 10:01 Go to previous messageGo to next message
The rear windows have a plate with two plastic grommet that guid the window up and down. They should be pretty much fixed.
Good Luck.
gpvm
Re: TA22 rear window winder operation Mon, 15 August 2005 10:02 Go to previous messageGo to next message
so I have to remove the plate from the car I suppose? How do I do that please?
mynameisrodney
Kellyville, Sydney
Re: TA22 rear window winder operation Mon, 15 August 2005 12:34 Go to previous message
its a painful process involving a lot of fidling. i cant remember the exact order of how to take the bits out Confused .
one bit of advice i can give you is to make sure you mark the location of all the 'locating nuts'(i dont know what they are called but you will know them when you see them) on the car by tracing or scoring around them. these help make sure that the window winds up into the correct final postion and if you dont mark them, you will have to work them out from scratch.
chris
Previous Topic:1ggze Idle stepper motor on WOLF3d
Next Topic:metal coating/polishing
Current Time: Mon Nov 2 06:18:37 UTC 2026
Total time taken to generate the page: 0.010045051574707 seconds
