Toymods » Tech & Conversions » 1ggze Idle stepper motor on WOLF3d
rx793
Perth, Western Australia
1ggze Idle stepper motor on WOLF3d Sun, 14 August 2005 12:07 Go to next message
Hey guys, just wondering is there is any possible way to hook these up on the wolf? just so i can have easy cold starts and for use wit h the air con n stuff.
If not, is there a solenoid that i can replace the motor with?
Steve
Grant
Newcastle, NSW, Australia
Re: 1ggze Idle stepper motor on WOLF3d Sun, 14 August 2005 21:50 Go to previous messageGo to next message
Steve, you'd be better asking the guys from Wolf.
stradlater
Arthurs Creek, Victoria
Re: 1ggze Idle stepper motor on WOLF3d Mon, 15 August 2005 06:34 Go to previous messageGo to next message
COUGH.. LPG... COUGH....
Re: 1ggze Idle stepper motor on WOLF3d Mon, 15 August 2005 11:10 Go to previous messageGo to next message
find a a/c/ idle-up solenoid from a camira with EFI - the thing needs 12V to open up - if you want to adjust the amount of air going thru, you need some kind of inline bleed valve.
failing that, get the AC idle-up hardware from a 5me - you'll need the:
-VSV valve
-any relay to drive it
-vacuum-operated air-valve screwed into the front end of the plenum
-piping to suit
it too just needs 12V to run the relay then vacuum is used to drive the dashpot on the valve.
either of these will need to take into account the fact that it might see boost?
Re: 1ggze Idle stepper motor on WOLF3d Mon, 15 August 2005 13:24 Go to previous message
There's a few options for idle control - either use what's on the engine (if your ECU can handle it - i.e. steppers need a couple of extra wires, and hence aux outputs), or use something simple, like the hose type idle air valve found on top of the rattle cover on EFI 250 Ford engines. Cheap, easy to fit, etc. Remember to reverse wire a 1N-4004 diode in line with it too.
Previous Topic:Stock 4AC clutch + gearbox + diff strong enough for 4AGE?
Next Topic:TA22 rear window winder operation
Current Time: Mon Nov 2 03:34:58 UTC 2026
Total time taken to generate the page: 0.0045480728149414 seconds
