Toymods » Tech & Conversions » installing k&n pod filter
celica86
August 2005
icon7.gif  installing k&n pod filter Sun, 14 August 2005 12:34 Go to next message
just recently purchased a k&n pod filter for my st162 gen 1 3gse celica could anybody give me some tips for installing it
should i remove the factory afm or install it after the afm as it wont restrict the pod any help would be greatly appreciated.
StuC
Re: installing k&n pod filter Sun, 14 August 2005 12:41 Go to previous messageGo to next message
install it after the AFM-if u take away the AFm your car wont work basically
Its also a good idea to box it up and get a CAI happening.Best thing would be to run batteryu to boot, make big airbox with cold air feed from box to front bar somewhere. EAsier still, get K&N panel filter
jonchai
Adelaide - Race Central
Re: installing k&n pod filter Sun, 14 August 2005 14:09 Go to previous messageGo to next message
as said above, unless you're using an aftermarket ECU that doesnt need AFM, you HAVE TO HAVE an AFM. and yes the pod filter goes before AFM Rolling Eyes
I thought we had a massive discussion on this before!! not again...buy some tubing from Mitre 10 (they're like $3.50/m) and stick it in front of youre car leading to the pod.....if the cops pull you over for it.....yank it off there and then....simple!
I have had this on my car for more than a year now and never had a problem with it!...be warned....this will become the lowest part of the car and have a few metres of the stuff spare at home as it will need replacing everynow and then Very Happy works wonders tho
VeeP
May 2005
Re: installing k&n pod filter Sun, 14 August 2005 15:14 Go to previous message
or, do what i did. Run pipe off the AFM to ur front bumper and fit ur air filter to the end of the pipe. Ideally, you want it low but hidden, and if at all possible behind a vent or grille, or just have it slightly protruding from the bottom of your car. Be warned, if its poking out the bottom of ur car, u must be very careful going over bumps (mine is this way and im yet to have any problems).
Previous Topic:4AGTE SETUP
Next Topic:Where to start (adelaide)
Current Time: Wed Oct 28 05:44:25 UTC 2026
Total time taken to generate the page: 0.0092568397521973 seconds
