Toymods » Tech & Conversions » Which Starter motor for T50.
20valve69corona
Which Starter motor for T50. Sun, 14 August 2005 20:49 Go to next message
What starter motor should i be using for a T50 bolted to a 20V.
this is quite urgent if anybody can help.
Will
emmac
Gippsland Lakes. Vic.
Re: Which Starter motor for T50. Sun, 14 August 2005 22:50 Go to previous messageGo to next message
G'Day Will
The smaller diameter starter from the 20v engine needs a little alteration to it's mounting housing to bolt up. The earlier model larger diam. starter from 16v engine bolts straight up. So you could use either.I may have one of each here if you are stuck for one.
emmac.
20valve69corona
Re: Which Starter motor for T50. Sun, 14 August 2005 23:53 Go to previous messageGo to next message
excellent. i have the smaller 20v one but the bottom hole won't match up. Is the 16v starter much bigger than the 20v one?
Will
emmac
Re: Which Starter motor for T50. Mon, 15 August 2005 08:03 Go to previous message
20valve69corona wrote on Mon, 15 August 2005 09:53
G'Day Will
Yes. That's why you alter the mounting housing to enable fitment. The 16v starter is considerably larger & heavier than the little 20v one. I'd consider the 20v starter to be a better unit.
emmac.
Previous Topic:yokely dokely
Next Topic:MX73 cressida/chaser front suspension conversion
Current Time: Wed Oct 21 13:56:39 UTC 2026
Total time taken to generate the page: 0.0048959255218506 seconds
