Toymods » Tech & Conversions » Lower your car to any height?!?!
Matty P
Canberra ACT
Lower your car to any height?!?! Mon, 15 August 2005 03:13 Go to next message
I've seen a few adverts lately from suspension places offering to "lower your car to any height" for a fixed cost.
Any ideas on how they acheive this? Some of the possibilities I have considered include:
  1. Having an infinite variety of different height springs
  2. Chopping standard springs to the required height
  3. Allowing you to select the height from limited options (eg. low and superlow)
I know I could just ring one of these places and ask, but what would be the fun in that? Razz
Corona RT142
Campbelltown
Re: Lower your car to any height?!?! Mon, 15 August 2005 03:24 Go to previous messageGo to next message
when i wanted springs for my corona i ordered them to any height i wanted, it was the same price thru whiteline whether i wanted them standard ride height or 2 inch's lowered didn't ask about any others but i assume it is the same.
Re: Lower your car to any height?!?! Mon, 15 August 2005 03:36 Go to previous messageGo to next message
They either a) have them custom made to the height you want or b) reset their height.
a) is better in that you can get the spring rate you want to properly suit the car and the new height.
b) is better in that it's cheaper, but may result in softer suspension due to the reduced spring rate.
Re: Lower your car to any height?!?! Mon, 15 August 2005 03:57 Go to previous messageGo to next message
there are also spring winding machines whereby you choose a certain diameter wire, diameter coil, and then the machine can wind in cetain rates, and progessive rates, depending on the coil seperation/effective wire length...
i thought K-Mac had been doing this for ages?
edt: oh wait.. JCMF already said that Razz
is common for coil-ober sized springs, but a spring winding machine of suficient decentness should be able to do any diameter sprign with any rate you desire....
[Updated on: Mon, 15 August 2005 13:54]
Re: Lower your car to any height?!?! Mon, 15 August 2005 13:49 Go to previous messageGo to next message
There are even fat cousins that you can put in the car. You then select the required height based on cheeseburger intake.
...did I just say that?
Re: Lower your car to any height?!?! Mon, 15 August 2005 13:53 Go to previous messageGo to next message
mrshin wrote on Mon, 15 August 2005 23:49
nah i think thats an american thing...
two fat cousins after 6 cheeseburgers each, gives great traction for your buick 3800 3.8 V6 taarbo siik maaate Wink
but only in a 5000lb car that does 11's on half throtle... full street trim, stock motah.....
Matty P
Canberra ACT
Re: Lower your car to any height?!?! Mon, 15 August 2005 22:51 Go to previous message
I've heard that bags of cement in the boot work well too Razz
Previous Topic:2T-B vacum help needed
Next Topic:What happens if you dont use etch primer on Metal ????
Current Time: Sun Nov 1 13:23:03 UTC 2026
Total time taken to generate the page: 0.038712978363037 seconds
