Toymods » Tech & Conversions » metal coating/polishing
DamMR2T
metal coating/polishing Mon, 15 August 2005 04:35 Go to next message
I have looked in these forums for any past info, but not what i was after.
Can anyone give an idea of the cost to get something polished or coated in something such as chromed?
I want to get my rocker cover(maybe other parts) done, and all i've seen is threads on how people do it themselves. Is it that expensive, can anyone recommend a place in Sydney.
What about bead blasting something?
Re: metal coating/polishing Mon, 15 August 2005 04:54 Go to previous messageGo to next message
So what is it you want? Polishing, coating, plating or bead blasting? These are all very different processes.
DamMR2T
Re: metal coating/polishing Mon, 15 August 2005 12:03 Go to previous messageGo to next message
I know they are all very different things, i am trying to work out the best cost/look ratio.
For starters, how much to polish a rocker cover as opposed to getting it chromed?
mynameisrodney
Kellyville, Sydney
Re: metal coating/polishing Mon, 15 August 2005 12:19 Go to previous message
if you have access to a bead blaster then blast it followed by a good polish. this will cost you some polish and possibly a small charge for usage of the bead blaster depending on who you know.
do you have a polishing wheel or a bench grinder which you can attach one to? i have had good results using my polishing wheel even without blasting if the condition is ok to begin with.
also it depends what type of finish you like. apart from costing different amounts, all all the processes you mentioned are going to look very different. so take take a look around a decide on what look you like first, and then try to find a cost effective way to do it.
chris
Previous Topic:TA22 rear window winder operation
Next Topic:4age - haltech e6k requirements
Current Time: Mon Nov 2 06:27:57 UTC 2026
Total time taken to generate the page: 0.0048489570617676 seconds
