Toymods » Tech & Conversions » t-vis na cams into ze?
feral4mr2
Bundaberg, Qld.
icon5.gif  t-vis na cams into ze? Tue, 04 June 2002 11:25 Go to next message
Rolling has anyone in this forum put the t-vis ge cams into a ze motor? they are supposed to have bigger lift or something and apparently produce a bit more gogo. i would like to do it if i know there is some sort of benifit.
thanks. Freak
dorikin
NE Melbourne
Re: t-vis na cams into ze? Tue, 04 June 2002 11:52 Go to previous messageGo to next message
can't say that i've done this, but according to what i've heard, this is common paractice. the TVIS cams have higher lift and longer duration that any other cams up till the 20Vs... so go for it, it should in theory be good for some kind of benefit!!!
if someone can be botheref digging up the specs, post them here so we can compare... i know Bill will know...
AE82TwinCam
Canberra, ACT
icon10.gif  Re: t-vis na cams into ze? Tue, 04 June 2002 12:43 Go to previous messageGo to next message
Shocked
wow, there may be some use for my old 4age yet!! Rolling
I would really like to know if this is of any real benefit!
-Andrew
AE82TwinCam
Canberra, ACT
icon9.gif  Re: t-vis na cams into ze? Wed, 05 June 2002 01:45 Go to previous messageGo to next message
aww c'mon someone has to know, if this such a common practise and all...
-Andrew
TA22-3SGTE
MACKAY
Re: t-vis na cams into ze? Wed, 05 June 2002 13:00 Go to previous messageGo to next message
Ok I heard the same thing about two years ago and so decided to measure up both cams , With the cams still in the motors I measured and dialed up both TVIS and ZE cams and they both had the same duration and lift .
Trevor
jazae86
Re: t-vis na cams into ze? Wed, 05 June 2002 14:14 Go to previous messageGo to next message
I was just at club4AG and they suggest:
7.56/7.56 lift for bigport
7.1/7.1 for GZE. (in/exh, all mm)
There is also longer duration on the big port cams.
Either TRD bible or 4AG II book suggests a difference of 8deg. Up from 232 to 240deg from memory.
Earlier AW11 GZE may well have TVIS cams, maybe even into AE92, but at some point they surely changed.
If you have lower lift and duration type, it would do well to source a set of TVIS cams for the right price. 8 deg and .4mm of lift may seem small, but for the little cost, I think it would be worth the effort.
A friend is putting my spare cams into his turbo GZE, but funning thing is: he needs my spare RWD manifold for his GZE: aparently the FWD manafold's ports are too small. (He actually put manifold on motor and found out!).
Looks like there are many variations of the GZE as there are 4AG.
Jaz
Note: non interferance and 'turbo' piston design of GZE pistons means extra lift is not an issue.
AE82TwinCam
Canberra, ACT
Re: t-vis na cams into ze? Thu, 06 June 2002 00:51 Go to previous message
cool..
Guess I'll be pulling the ol' 4age apart in the holidays then Smile
-Andrew
Previous Topic:Just brought a 1980 Celica, then what do I do now?
Next Topic:FWD Hub Nuts
Current Time: Thu Nov 19 20:01:37 UTC 2026
Total time taken to generate the page: 0.0051109790802002 seconds
