Toymods » Tech & Conversions » What happens if you dont use etch primer on Metal ????
Kravit
March 2005
icon5.gif  What happens if you dont use etch primer on Metal ???? Mon, 15 August 2005 08:50 Go to next message
Hey guys,
I was wondering when spraying big surface bare metal if it is ok not to use etch primer on it and just normal primer on it ???
Anything will happen to it in long run or short run ??
petespipes
logan river brisbane
July 2005
Re: What happens if you dont use etch primer on Metal ???? Mon, 15 August 2005 18:02 Go to previous message
specialist info on paint is so easy to get from any paint retailer.But.If you require info from non specialists-apparently surfaces like stainless or gal need etch primer where mild steel does not.If your mild steel has been left bare metal for any period at all [over an hour or 2] it should be "rust converted" before being primed.
Seriously though,for a good result get the right advice and please remember that paying a little extra to stay with a product range that is designed and formulated to work together ie wattyl products or any reputable Australian brand will put you in front and also allow you to access reliable product info and advice.Ask a proffessional for advice and take some cash with to buy some good shit,will save a lot of your labour by doing it once only......Best of luck! Smile
Previous Topic:Lower your car to any height?!?!
Next Topic:02 Sensor?
Current Time: Sun Nov 1 19:02:50 UTC 2026
Total time taken to generate the page: 0.039791822433472 seconds
