Toymods » Tech & Conversions » Painting with enamel..... or a bumper bar
Leighp
NY
Painting with enamel..... or a bumper bar Mon, 15 August 2005 13:08 Go to next message
Have a mate that wants to spray up a bodykit and rear bar, is it better to use enamel or acrylic
and with either how would he do it and what ratios etc.
L
Hodgo
Re: Painting with enamel..... or a bumper bar Mon, 15 August 2005 13:18 Go to previous messageGo to next message
touch-up pens are best, or whiteout perhaps even a posca pen
Re: Painting with enamel..... or a bumper bar Mon, 15 August 2005 13:43 Go to previous messageGo to next message
Hodgo wrote on Mon, 15 August 2005 23:18
LOL, someones been on the piss tonight Razz
depends what is compatible with the material the bar/kit are made from... at the very least do a test area to make sure it doesn't royally fark it up...
i'd guess acrylic is safe usually.. perhaps??? better than a posca pen Razz
[Updated on: Mon, 15 August 2005 13:47]
Leighp
NY
Re: Painting with enamel..... or a bumper bar Mon, 15 August 2005 14:59 Go to previous messageGo to next message
hodgo is never straight haha lol
i shall let him know eh haha
thanks toby for making art of spraypainting
anyother options
petespipes
logan river brisbane
July 2005
Re: Painting with enamel..... or a bumper bar Mon, 15 August 2005 17:06 Go to previous messageGo to next message
I am no paint expert but it is useful to know that normal acrylic auto paint can be used on a plastic surface after priming with a "plastic primer" have used it on the dirt bikes over the years,works well.
also i believe if the surface is flexible or likely to flex paint can be mixed with a plasticizer [hows it spelt] included to allow some flex in the paint finish without cracking so easily.
Phone the kit seller\installers for advice on what they use might be the go.I asked them how they attach bonnet grilles,scoops etc and was informed Sikaflex automotive sealant\adhesive.Stuff needs to remain clamped for 24 hours but certainly does the job.
Good luck! Smile
Leighp
NY
Re: Painting with enamel..... or a bumper bar Tue, 16 August 2005 13:25 Go to previous messageGo to next message
any further additions??
Dale_ta22
Forster NSW
Re: Painting with enamel..... or a bumper bar Wed, 17 August 2005 01:11 Go to previous messageGo to next message
Either would do the job fine, consider 2 pac will dry harder, so is more likely to crack, and chip badly.
If it was me I'd probably lean towards acrylic.
Ratios you'd be generally be looking at about 1.5:1 (thinners:paint). Which is 1.5 litres of thinners to every litre of paint.
Normal primer should do the job fine, but tell him to watch out for static when he goes to paint since they're likely to be plastic/fibreglass panels. Wink
Leighp
NY
Re: Painting with enamel..... or a bumper bar Wed, 17 August 2005 06:59 Go to previous messageGo to next message
what is static, is it a thing (as in electricity) or a brand
thanks also mate
September_Squall
Melbourne, Australia
March 2005
Re: Painting with enamel..... or a bumper bar Wed, 17 August 2005 18:45 Go to previous messageGo to next message
Static as in electricity, as is the regular result of rubbing fabric against plastics or fibreglass.
As for your thread title, I'd prefer to paint with enamel than a bumper bar. May just be me, but I can't really see the bumper bar doing as good a spray job as the enamel really.
ae86 slide
gold coast
Re: Painting with enamel..... or a bumper bar Thu, 18 August 2005 05:46 Go to previous messageGo to next message
prep is important so sand the surface with 400 grit sand paper then spray on plastic prime (making sure surface is completly clean before spraying, sand again with 400 then 800, clean again.
for finish coat i would recomend 2 pac, dries harder as previosly stated and i believe is actually stronger than acrylic, talk to paint store about mixing as it can vary with diferent products, 2 pac takes alittle longer to tack off which means its easier to keep a wet edge when spraying, prob only need two coats, possibly with a light 800 sand in between.
being 2 pac no clear required, makes it a bit more easy.
Leighp
NY
Re: Painting with enamel..... or a bumper bar Thu, 18 August 2005 11:53 Go to previous messageGo to next message
yes squall that is a very good point that u brought up, silly me
ok so we figure 2pac is the go, were do i get and can a home handy man apply it or is it a case of a pro job
L
Dale_ta22
Forster NSW
Re: Painting with enamel..... or a bumper bar Fri, 19 August 2005 00:50 Go to previous messageGo to next message
2 pac is better left to the pros, to get proper results you need an oven to bake the paint in after applying it.. plus icocyanates are bad and it's likely illegal to apply it at home
ae86 slide
gold coast
Re: Painting with enamel..... or a bumper bar Fri, 19 August 2005 23:06 Go to previous message
dont know about illegal, but definatly true about baking it, but thats the difference between getting it profesionaly done or saving some money and doing it your self,
As long as you do it in a fairly dust free environment it should come out fine,
as for buying it look in the phone book dude.
automotive paint, let your fingers do the walking
Previous Topic:where do i go for tune up in melbourne
Next Topic:can u turn boost down below stock pressure?
Current Time: Thu Oct 29 15:57:41 UTC 2026
Total time taken to generate the page: 0.14618301391602 seconds
