Toymods » Tech & Conversions » Grinding noise..spigot bearing?
papercut
Grinding noise..spigot bearing? Tue, 16 August 2005 04:20 Go to next message
Hi guys
Recently i've been noticing a grinding noise coming from where the gearbox is - this is only noticable in 1st gear, and sounds not healthy. The only thing i can put it down to is a worn spigot bearing, as i did not change it when i put my new clutch in (3 months ago). It is a dry sound and gets worse in higher revs only in first.
What else could it be if not? does a worn spigot have a sound in every gear in anyones experience?
It's piss annoying cuz i try to avoid first gear Crying or Very Sad
rob_RA40
c'town, NSW
Re: Grinding noise..spigot bearing? Tue, 16 August 2005 04:31 Go to previous messageGo to next message
is the noise there when u sit in neutral with the clutch out as well?
could be the clutch throwout bearing.
RobertoX
Re: Grinding noise..spigot bearing? Tue, 16 August 2005 05:08 Go to previous messageGo to next message
The spigot bearing will only make noise when the clutch is disengaged. otherwise the gearbox input shaft and crank where the spigot is is practically a solid piece (ie when the clutch is out), then the spigot bearing is not rotating and wont make any noise.
It could be the thrust bearing, but I would expect it to make noise in every gear (??)
Edit: Always change the stupid spigot bearing when you remove the clutch... such a pain in the butt to remove the stupid gearbox again when you find it makes an awful noise Confused
[Updated on: Tue, 16 August 2005 05:09]
papercut
Re: Grinding noise..spigot bearing? Tue, 16 August 2005 06:14 Go to previous message
nah in neutral its fine.
i replaced the throw out bearing and made sure the fork was attached properly so shouhldn't be any dramas there.
ONLY in first gear it grinds
also i fogot to mention, when i'm in 4th particularly, travelling normally and i want to pick up the pace, i step on the throttle and it grinds and sounds unhealthy in the area i mentioned the sound was coming from.
maybe something in the flywheel/bottom end?
Previous Topic:RT-142 IRS LSD Options
Next Topic:diff 'lokka' in a hilux
Current Time: Mon Nov 2 13:38:43 UTC 2026
Total time taken to generate the page: 0.0045490264892578 seconds
