Toymods » Tech & Conversions » Transmission coolers
Soarer
Wollongong
Transmission coolers Tue, 14 May 2002 13:45 Go to next message
Has anyone had experience purchasing/installing one of these?
What sort of core is used ?
Approximate prices to suit an A340E Soarer box ?
Could I install one myself ?
Any additional pumps required ?
How about an inline filter to prolong the life of the box ?
Manny
Re: Transmission coolers Tue, 14 May 2002 14:26 Go to previous messageGo to next message
I fitted one years ago on a worked 6 cycl. crummydoor - worked a treat - stopped cooking the trimatics during extended helis.
Still got it if you want it for nothing - dimmensions are about 200mmX300mmX15mm.
From memory you've already got a cooler line running to the bottom of your radiator - just needs to be tapped into the return line with some quality hose and clamps - probably mount it inside your LHS wheel arch behind front bar opening - as per stock IC in RHS position.
I assume there's already a filter in your autobox as in most/all others.
Regards
[Updated on: Tue, 14 May 2002 14:29]
Allan
Re: Transmission coolers Wed, 15 May 2002 00:15 Go to previous messageGo to next message
buy a newie you want one thats perfectly clean inside i got one from supercheap $80 "V8" size
if you like to light up the tires get another A/C cooler for the front pump lots of petrol and kero thru it then blow it out with air flush again and then air again! and use that! about the best auto cooler you can get and it looks factory too Very Happy
Allan
Manny
Re: Transmission coolers Mon, 20 May 2002 13:24 Go to previous message
Simon
If you still want to get your hands dirty, here are some pics of a power steering cooler install on a Soarer. Same theory applies for the autobox cooler.
http://www.geocities.co.jp/MotorCity-Rally/2280/ps c.html
Previous Topic:vibration from 3TGTE
Next Topic:Toyota ECUs
Current Time: Wed Oct 28 00:04:01 UTC 2026
Total time taken to generate the page: 0.026415109634399 seconds
