Toymods » Tech & Conversions » MA70 vs GZ20 Brake Calipers
MR 1JZ
MA70 vs GZ20 Brake Calipers Tue, 16 August 2005 05:15 Go to next message
I was told today that the brake pads for an MA70 and GZ20 in the front are identical, does this mean that when you perform the 300mm upgrade you are only really upgrading the rotors and you dont need to change the calipers?
the reason I am asking is I have a set of rotors without calipers sitting at home, is it worth getting them machined up and fitting them in the hope of having some sort of upgrade? as larger rotor surface area means better heat dispersion Smile
Matt
MR 1JZ
Re: MA70 vs GZ20 Brake Calipers Tue, 16 August 2005 05:18 Go to previous messageGo to next message
even better!
can someone with one of those EPC Part Number things please tell me if the brake calipers off an MA70/JZA70 have the same part number as the GZ20 calipers
and if the brake pads are the same (this is just to establish whether the person who told me is talking shit or not)
You'll probably find even if the caliper is the same, the position of the caliper wont be right.
MR 1JZ
Re: MA70 vs GZ20 Brake Calipers Tue, 16 August 2005 05:25 Go to previous messageGo to next message
nath could you care to elaborate on that one dude?
im not quite following you...
you do know the MA70 brake conversion is a bolt on conversion...i.e. hubs dont need to be changed etc
Re: MA70 vs GZ20 Brake Calipers Tue, 16 August 2005 05:42 Go to previous messageGo to next message
Sorry, was in the middle of something.
Think of it like this, the R32 Skyline and R33 Skyline calipers are essentially the same. The R32 suits a 280mm disc, and the R33 a 296mm disc. They both take the same pads.
Because the outside of the R33 disc is 16mm further out, the "legs" where the caliper bolts to the strut are 8mm longer to accomodate the bigger diameter. I'd assume the case to be the same for the Soarer and Supra.
The Supra caliper, while taking the same pad may have different mounting brackets.
[Updated on: Tue, 16 August 2005 05:42]
Re: MA70 vs GZ20 Brake Calipers Tue, 16 August 2005 05:44 Go to previous messageGo to next message
NOTE: Although I could be wrong and the actual brackets on the strut are where the difference is, by all means, prove me wrong Razz
MR 1JZ
Re: MA70 vs GZ20 Brake Calipers Tue, 16 August 2005 06:00 Go to previous messageGo to next message
ahhhhhhh
thanks for clearing that up
I might give it a whirl when I do the front pads and just see if it works
if it doesnt then its no biggie i guess Smile
Re: MA70 vs GZ20 Brake Calipers Tue, 16 August 2005 06:02 Go to previous messageGo to next message
Exactly, will only take 30 secs to compare.
BlackSupra
Re: MA70 vs GZ20 Brake Calipers Tue, 16 August 2005 09:17 Go to previous messageGo to next message
You do need to swap the calipers when swapping over to the bigger ma70 rotors.
GTtwin
Newcastle, Australia
August 2005
Re: MA70 vs GZ20 Brake Calipers Tue, 16 August 2005 09:43 Go to previous messageGo to next message
I know that Rear's are identical, not sure about fronts.
I stole my mates MA rears and put them on my GZ. Straight fit.
Having both cars sitting in the yard is useful.
Pads are identicle, same as MX73 Cressida.
snail
Re: MA70 vs GZ20 Brake Calipers Wed, 17 August 2005 05:14 Go to previous messageGo to next message
Cailpers are the same. Brake pads are the same. The difference is is the brackets that the calipers slide on. Obvously the bigger rotors have bigger brackets to clear them. Smile
MR 1JZ
Re: MA70 vs GZ20 Brake Calipers Wed, 17 August 2005 05:23 Go to previous message
snail you have a group of pm's
all from me...
Previous Topic:wiring loom diagnosis
Next Topic:*A70 - *Z20 floor pans same?
Current Time: Sat Oct 24 17:25:58 UTC 2026
Total time taken to generate the page: 0.0043301582336426 seconds
