Toymods » Tech & Conversions » TA27 Celica, Need LSD, Suspension upgrades
racer98
Los Angeles, California ,...
TA27 Celica, Need LSD, Suspension upgrades Wed, 17 August 2005 07:26 Go to next message
Hello all its been a whole while since I posted last up here I have a Jap spec TA27 Celica and I would like too get the follwing
1) LSD
2) GAS adj shocks or some good ones too replace the worn out ones I have in the car now
3) sway bars
Since the TA27 was never imported into the usa and the TA22 shock inserts and the RA25 Front inserts for the struts are completely differnt from the TA27 I need some help with x-refrence some replacement ones
4) Brake upgrade for the fronts only.
any help and sugestions would be grate but if you have something for sale like this Im located in USA so shipping from aussie too usa can be for the most parts very costly.
Lambolica
Northwestern Sydney
Re: TA27 Celica, Need LSD, Suspension upgrades Wed, 17 August 2005 07:54 Go to previous messageGo to next message
Australia Never got the TA27 either so parts are few and far between, River may have a better idea than I however
1) LSD for these are rare, Your best bet is to find a Sprinter owner and see what they have. You should have a T series diff in it and may find a JDM sprinter diff will fit Thou axles may differ.
2) Find what people over there use in their TA22's and use them
3) As per 2
4) Search for TA22 brake upgrades, starting point
As far as I'm aware the TA27 has the front setup of a TA22 (concidering it shares the same engine and hense probably crossmember and struts.) I may be proven wrong however.
What is the ID code on the build plate? TA27-???
racer98
Re: TA27 Celica, Need LSD, Suspension upgrades Wed, 17 August 2005 08:12 Go to previous messageGo to next message
thanks for the reply yeah I will have too do some research on this this had too break the car down for the shock and spring replacement but talk about having too deal with fools on my end here in the states. I had too throw it back too gether and still have not been able too find my replacement part for it.
thanks.
jeffro RA28
Tamworth
Re: TA27 Celica, Need LSD, Suspension upgrades Wed, 17 August 2005 09:32 Go to previous messageGo to next message
If the shock inserts for the ta22 are the same as the ra28, ra23 or ta23, read no further.
Have you tried using the shock inserts from a ra28 ra23 or ta23?
I am unsure of the difference of ta22 shock inserts vs xA23, RA28 ones. But if the ra28, ta23 and ra23 are different from the ta22 it may be worth trying them.
For brake upgrades try these links
http://www.toymods.org.au/phill_brake/
http://www.toymods.org.au/sprinter_front_brakes/
For rear brakes
http://www.toymods.org.au/xA2x_rear_discs.html
[Updated on: Wed, 17 August 2005 09:33]
racer98
Re: TA27 Celica, Need LSD, Suspension upgrades Wed, 17 August 2005 16:05 Go to previous messageGo to next message
thanks for the link
also wanted too get some better after market spring that will lower the car but RA28 is from a ????
Lambolica
Northwestern Sydney
Re: TA27 Celica, Need LSD, Suspension upgrades Thu, 18 August 2005 02:14 Go to previous message
RA29 for you guys over there...
Our RA28 is your RA29 (in basic form ignoring the different engine and some inteior differences)
[Updated on: Thu, 18 August 2005 02:15]
Previous Topic:Can you just fit lowered springs?
Next Topic:ma70 speedo cable snapping
Current Time: Wed Nov 18 21:02:31 UTC 2026
Total time taken to generate the page: 0.0057837963104248 seconds
