Toymods » Tech & Conversions » Turbocharging 4AGE .
salman
karachi
August 2005
Turbocharging 4AGE . Wed, 17 August 2005 10:03 Go to next message
HI ALL .
I want to turbo charge 4AGe i have done all most every thing except the fueling system .
I have option for 2 things
1. FMU 12:1
2. AIC HKS
i aim to run 6 psi rite now . Crying or Very Sad
xxxplosive
August 2005
Re: Turbocharging 4AGE . Wed, 17 August 2005 11:03 Go to previous messageGo to next message
hmm a factory engine may hold 5 psi standard but i wouldnt punch it too hard until u work the head and lower compression. otherwise bye bye pistons... lol what mods u done to it so far?
salman
karachi
August 2005
Re: Turbocharging 4AGE . Wed, 17 August 2005 12:49 Go to previous messageGo to next message
i few people told me tht 4age can take up to 10 to 12 psi ..
no mods just simple turbo installation
will a blox 12:1 FMu will be fine for 6 psi of boost .
feral4mr2
Bundaberg, Qld.
Re: Turbocharging 4AGE . Wed, 17 August 2005 14:02 Go to previous messageGo to next message
salman wrote on Wed, 17 August 2005 22:49
indeed with the right tuning and good intercooler.
salman
karachi
August 2005
Re: Turbocharging 4AGE . Fri, 19 August 2005 16:07 Go to previous messageGo to next message
pleas explain me what is good tuning in your eye ,. Smile
and who to cheat the map,
feral4mr2
Bundaberg, Qld.
Re: Turbocharging 4AGE . Fri, 19 August 2005 22:39 Go to previous messageGo to next message
running aftermarket engine management (microtech etc)and having someone that 'knows' what they are doing tune it.
i run a gze ECU set-up on my 4age-gte, but i lowered the c/r a bit because the ECU is not tuneable.
salman
karachi
August 2005
Re: Turbocharging 4AGE . Sat, 20 August 2005 07:40 Go to previous messageGo to next message
which GZE ECU do u have .. ??
for fueling till 5 psi . isnt a BLOX FMU 12:1 will work go0d .
feral4mr2
Bundaberg, Qld.
Re: Turbocharging 4AGE . Sat, 20 August 2005 11:13 Go to previous messageGo to next message
i'm running the aw11 bigport 4agze ECU, 365cc injectors, AFM, fuel pressure reg, dist, wiring harness etc on my bigport 4age (9.4:1 casties but useing a 2 HG's, approx 2.6mm) @ 12psi. i still useing the old original 4age fuel pump at the moment too.
i know nothing of add on ECU doobies (BLOX FMU 12:1??) as i havnt had the $$$ or the need yet to look into them.
salman
karachi
August 2005
Re: Turbocharging 4AGE . Mon, 22 August 2005 05:56 Go to previous messageGo to next message
what is the power out put ..
feral4mr2
Bundaberg, Qld.
Re: Turbocharging 4AGE . Mon, 22 August 2005 12:51 Go to previous messageGo to next message
only ever been on a dyno couple years ago when it was only at 7psi (engine was not long run in and i didnt have my dual stage contoller on at the time). got an ok 142rwhp. Smile
havnt had it checked since i've been running 12psi, and it's been flogged HEAPS at 12psi.
Re: Turbocharging 4AGE . Mon, 22 August 2005 13:27 Go to previous messageGo to next message
hahha ahhahahah Laughing Laughing Laughing
completely wanky FPR.. they don't say 12:1 what tho Wink shep? cheeses??
http://www.prostreetonline.com/buy/blox_fmus/
Quote:
BLOX FMUs
The Blox fuel management unit is designed to increase the fuel pressure as the pressure in the intake manifold increases. The Blox FMU is a universally design product with a 12:1 fixed ratio. The FMU is used on fuel injected vehicles, either supercharged or turbocharged, using the factory electronic engine management system. Blox FMU’s are available in blue, red, gold and gun metal.
http://store1.yimg.com/I/twincamtech_1852_10328181
salman
karachi
August 2005
Re: Turbocharging 4AGE . Mon, 22 August 2005 13:34 Go to previous messageGo to next message
dose'nt it work that way . honda at 8psi produce . 180+RWHP... Confused
Re: Turbocharging 4AGE . Mon, 22 August 2005 13:37 Go to previous messageGo to next message
salman wrote on Mon, 22 August 2005 23:34
what are you talking about?? you sound like you have much better drugs than me Wink
the above is a fuel pressure regulator.. manifold reference pressure at top, fuel ports at bottom... it's even priced like a FPR??
dj_jewmaster
tasmania
August 2005
Re: Turbocharging 4AGE . Mon, 22 August 2005 14:22 Go to previous messageGo to next message
Mate you would be surprised how much of caining a car can take pistons are strong, the only thing that kills engines is detonation and leaning out, if the stock injectores, fuel pump and fuel regulator are good enough to deliver enough fuel its fine. For god sake I know some one that has turboed a 120y and a dirty old corolla that had like a 1.3 or some thing and made it fuel injected with mircotec and tuned it so it didn’t detonate and he super charged it and it went hard as. Good luck but I don’t know much about the 4ages as im asking as well im a Nissan man lol.
quest
u.s.a. south
Re: Turbocharging 4AGE . Mon, 22 August 2005 17:25 Go to previous messageGo to next message
go the miata forums if you want to turbocharge a 4age the "economical" way.
http://forum.miata.net/ubb/ultimatebb.php?ubb=foru m;f=1
Greddy offers a basic kit for the miata using these 'so called hacks', and they drive/perform impressively on their stock miata motors which are VERY similar to the 4age. Lots have copied, moded and improved it
http://roadster-chat.net/ubb/ultimatebb.php?ubb=fo rum;f=17
If you have a map 4age, you're in luck... as safc and other piggybacks are compatible and will raise the bar tuning-wise, for little money.
check out
http://www.homemadeturbo.com/
http://www.honda-tech.com/zeroforum?id=16
feral4mr2
Bundaberg, Qld.
Re: Turbocharging 4AGE . Mon, 22 August 2005 20:45 Go to previous messageGo to next message
oh oldcorollas that blox doobie is so prity, i must have one.. Laughing
i use the gze fuel reg, works fine.
05m0515
July 2005
Re: Turbocharging 4AGE . Mon, 22 August 2005 22:28 Go to previous messageGo to next message
Here's my buddy Drew's build up...
http://4agte.blogspot.com/
salman
karachi
August 2005
Re: Turbocharging 4AGE . Tue, 23 August 2005 06:02 Go to previous message
i really missunderstood that what are you trying to say ..i thought your Are saying that BLox is carp ... Crying or Very Sad . but remaove that concept .
i will visits the site which are recommaned by the guest and other ...
Previous Topic:Car paint color codes : newbie questions
Next Topic:Boost controller setup, 3sgte
Current Time: Thu Nov 19 11:36:48 UTC 2026
Total time taken to generate the page: 0.010206937789917 seconds
