Toymods » Tech & Conversions » Resetting stock toyota camry 4cyl 95 ECU??
owen3150
August 2005
Resetting stock toyota camry 4cyl 95 ECU?? Thu, 18 August 2005 06:37 Go to next message
Hey I'm running a stock 95' Toyota Camry 4cyl 2.2L with 98 octane petrol but I'm not sure if I need to reset my ECU (I'm a newb to this stuff)
Also is a cold air intake a good idea with the 98 octane petrol??
Stretch
Sydney,Hurstville
Re: Resetting stock toyota camry 4cyl 95 ECU?? Thu, 18 August 2005 07:43 Go to previous messageGo to next message
i dont think that you will need to reset the e.c.u
- if you install the c.a.i make sure you dont alter the m.a.p or the a.f.m which ever you have
terra
July 2005
Re: Resetting stock toyota camry 4cyl 95 ECU?? Thu, 18 August 2005 07:54 Go to previous messageGo to next message
run 91 octane
no use going higher in a 5sfe unless youre boosted.
to reset ecu pull the EFI fuse for 30 seconds.
cold air intakes are easy :{P
but not worth the money unles you spend less then $50
[Updated on: Thu, 18 August 2005 07:55]
owen3150
August 2005
Re: Resetting stock toyota camry 4cyl 95 ECU?? Mon, 29 August 2005 14:54 Go to previous message
Thanks Smiley =
Previous Topic:Help - Corolla SX instrument wiring
Next Topic:adjusting cam timing, what does what
Current Time: Sat Oct 24 11:05:11 UTC 2026
Total time taken to generate the page: 0.0050568580627441 seconds
