Toymods » Tech & Conversions » Carbie problem?
Smokey228
January 2005
Carbie problem? Thu, 18 August 2005 06:48 Go to next message
i got a 4af. every now and then when i go to start it, it wont kick over, for up to like 10secs of throttle play. one it finally does, it chockes and blows smoke. ive never had a mechanical problem with the car, and it was in my family since new.
my diagnostic is a flooding carbie. sytoms apart from this slow start, which only happens wen warm and off for a few minutes, is a slightly high idle. would this high idle be causing more fuel to fill the carbie wen on idol, then neccesary, so that wen i turn the car off it causes it to flood? then the tough start, could this be cause its flooded and 'drowning'? i notice once it finally turns over and i back on and off the throttle, it back fires, (i think), but that might be a leak ive had for a while jus emphasized... Razz
happened to me a few times in the last few weeks. how would i fix this? jus lower the idol? do i do that whilst the engine is running or off, then check, then off, then check? etc.
thanks in advance guys,
jason
Dale_ta22
Forster NSW
Re: Carbie problem? Thu, 18 August 2005 07:27 Go to previous messageGo to next message
I think it's more likely an ignition problem. Mine does similar when warm and has been left for 10 minutes or so, although it actually starts, just cranks for longer before it starts.
Mind you I know my timing's good, so I suspect the coil or leads...
Smokey228
January 2005
Re: Carbie problem? Thu, 18 August 2005 07:57 Go to previous messageGo to next message
i duno man, cause i got sum fat sh*t leads and they are pretty new. i think the coil is okay to, from wat i know, its pretty new.
one other thing, wen i turn the ignition off, it shudders whilst it shuts off, like a gentle stall almost. could i have a dirty carbie? maybe sum carbie cleaner. and i think a fuel filter at sum stage?
ill find out exactly wen the leads and coil where replaced and work accordingly...
thanks dale
Dale_ta22
Forster NSW
Re: Carbie problem? Thu, 18 August 2005 11:34 Go to previous messageGo to next message
Shudders as in runs on for a couple of seconds after you switch off the key? I've had that a couple of times...
Carby cleaner would be worth a try, as would fuel filter if it hasn't been done in a while. Though I've covered both of those bases with mine.
Check the throttle body on the carby for the other thing, mine gets stuck on slightly so has to be adjusted accordingly to compensate.
[Updated on: Thu, 18 August 2005 11:38]
Smokey228
January 2005
Re: Carbie problem? Fri, 19 August 2005 02:04 Go to previous message
so u still have the problem? or u fixed it with adjusting the throttle body?
the fuel filter im not sure about, so ill do that to be sure. but the carbie i cleaned about 11months ago, so i will do that. and ill get a new air filter.
sorta like a process of elimination, ill know wat its not if these dont fix it. Razz
thanks for ur help again dude.
Previous Topic:GT4 ST185 Clutch And Timing belt problem should i fix
Next Topic:supra sump and aristo sump
Current Time: Wed Nov 18 20:11:06 UTC 2026
Total time taken to generate the page: 0.0051920413970947 seconds
