Toymods » Tech & Conversions » Sealing Bog from Cracking in the future ????
Kravit
March 2005
Sealing Bog from Cracking in the future ???? Thu, 18 August 2005 12:52 Go to next message
Hey guys, I have done some repairs with bog on a car and i was wondering what are some ways i can help keep it from cracking in future ?
I have done alot of coats of primer on it already to seal surface realy well.
Re: Sealing Bog from Cracking in the future ???? Thu, 18 August 2005 23:34 Go to previous messageGo to next message
Best way to prevent moisture is to sandwich it between coats of POR15 paint. It completely seals it off.
As you've already primed it, your best bet is to get it painted. Primer won't provide moisture protection as it's quite porous Smile
Kravit
March 2005
Re: Sealing Bog from Cracking in the future ???? Thu, 18 August 2005 23:37 Go to previous messageGo to next message
Is there any reason why cant spray por 15 on the primer and recoat it ?
Re: Sealing Bog from Cracking in the future ???? Fri, 19 August 2005 00:09 Go to previous messageGo to next message
Not really I suppose, it should still seal everything in as it cures, only one way to find out Razz
mynameisrodney
Kellyville, Sydney
Re: Sealing Bog from Cracking in the future ???? Fri, 19 August 2005 00:11 Go to previous messageGo to next message
take it out and start over. justcallmefrank's method sounded good, and paint as soon as possible. i know you're probably not going to want to do it, but i personally would rather spend the time fixing it now, before it's all been sprayed.
chris
lumpy
Adelaide, SA
Re: Sealing Bog from Cracking in the future ???? Fri, 19 August 2005 03:56 Go to previous messageGo to next message
Kravit wrote on Thu, 18 August 2005 22:22
Bog once set doesn't really move/flex, unlike the steel surrounding it, which has a bit of flexibility. Although your paint film may be flexible it may not have the elongation/crack bridging you require if the steel moves/expands/contracts around the bog.
ChuckLandwehr
Re: Sealing Bog from Cracking in the future ???? Fri, 19 August 2005 05:09 Go to previous messageGo to next message
Reshape the metal first, then bog, with a maximum of 2mm thickness, any thicker, and there is no way the bog will stay stable, and not crack.
Use a microfine 2 part filler, and attach to the bare metal, which has been roughened with 60 grit, this provides a "key", so the bog does not fall out.
Por15 coat/prime, then paint as normal.
If it has been sitting with just primer on it for a while, start again, as there will be entrapped moisture in your primer. Primer is not just porous, but hydroscopic, ie. it will draw moisture into it from the air!!!
cheers Chuck.
Kravit
March 2005
Re: Sealing Bog from Cracking in the future ???? Fri, 19 August 2005 13:17 Go to previous messageGo to next message
Wouldnt any amount of bog crack then, because surface undeneath will move ? what about having it around areas of the car that dont sway much like the roof ??
I've also seen whole side panels boged up, huge dents in side of car filled with bog and these guys are pros aswe;;, wouldnt this just crack after few drives ???
[Updated on: Fri, 19 August 2005 13:26]
feral4mr2
Bundaberg, Qld.
Re: Sealing Bog from Cracking in the future ???? Fri, 19 August 2005 13:40 Go to previous message
i've bogged up plenty of panels over the years with the different cars i've owned. shite my old statesman i reshaped the whole rear quarter with bog (deffinatly thicker than 2mm). after ~2 years it still hadnt cracked or anything, and last time i saw it after i had sold it the panel was still fine.
all i've ever done was hit the metal with the grinder to give the bog a rough surface to adhere to, bog, sand, prime and paint. works for me anyways. Smile
Previous Topic:Jaycar IEBC and Autronic solenoid
Next Topic:13b turbo in TA22??
Current Time: Fri Oct 30 17:31:45 UTC 2026
Total time taken to generate the page: 0.0078420639038086 seconds
