Classifieds » Parts Wanted » 4age specs on map sensor
Stretch
Sydney,Hurstville
4age specs on map sensor Fri, 19 August 2005 05:52 Go to next message
hi all, my mate rekons that his map sensor on his ae86 is playing up and i need 2 check it but i dont have the specs for the ohm reading that i should get. does anyone have the specs for the resistance? any help will be great.
Scorpion
Menai area of Sydney
Re: 4age specs on map sensor Sun, 21 August 2005 07:05 Go to previous message
Map sensor is tested by voltage.
Red and black wires are 5v and earth respectively. (4.7v - 5.6v)
Yellow wire in the middle should read 0.3v-0.5v at low vacuum (100 mmHg)and vary up to 1.9v-2.1v at high vacuum (500mmHg).
So with ignition on and connector plugged into MAP sensor, suck on the vacuum tube and see if the voltage varies between 1/2 volt to 2v measured between the yellow and the black wire.
Previous Topic:car audio stuff
Next Topic:Apexi RSM G Sensor
Current Time: Sat Oct 31 18:21:32 UTC 2026
Total time taken to generate the page: 0.0043458938598633 seconds
