Toymods » Tech & Conversions » 3S-GTE
dale_8888
August 2005
3S-GTE Fri, 19 August 2005 07:57 Go to next message
will a 3S-GTE fit in a KE20?
I am getting a KE20 and seeing as though its RWD i wanna get it sideways...therefore requiring alot more power.
Is a 5K a better option because it fits in the original moutns?
Is it a good engine...5K that is?
tricky
July 2005
Re: 3S-GTE Fri, 19 August 2005 12:25 Go to previous messageGo to next message
5K and 3SGTE are somewhat different...
Is 5K a good engine? not really. It won't fulfill your hektik dorifto requirements bro.
Will a 3S fit? not without a degree of effort and experience. How heavy is a KE20? a 3SGTE may not even be legal.
PS... a 3S will fry clutches better than ya mum's tarago! Very Happy Very Happy
(dodgy reference to earlier post... Confused )
[Updated on: Fri, 19 August 2005 12:26]
tricky
July 2005
Re: 3S-GTE Fri, 19 August 2005 12:32 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=78236&start=0&rid=11470&S=dc665457ab b126c1706b181b93ac7f2e
now THAT would be a good 5K
M.W.P.
Rocky Mountains, Canada
Re: 3S-GTE Fri, 19 August 2005 12:41 Go to previous messageGo to next message
4AGE / 4AGZE would be better suited.
dale_8888
August 2005
Re: 3S-GTE Fri, 19 August 2005 15:36 Go to previous messageGo to next message
I sorta know a little bit of stuff!
With the clutch thing...I was going to change the gearbox too. I have heard that the SR20DET is an OK fit so I figured that the 3S would since it's a similar engine.
A 4AGZE will create enough power to drift something that light but I am curious how much would I need to work it to get say...150hp ATW?
Would a 4AGTE be better?
tricky
July 2005
Re: 3S-GTE Sat, 20 August 2005 08:26 Go to previous message
SR20 and 3SGTE are not at all comparable. 3SGTE never came in front engined RWD configuration, so you have to make fully custom mounts, work on a water outlet, and you have the problem that the engine was designed to sit on a slant of 15 degrees off vertical. This introduces issues in the form of poor oil draining. Some people keep the engine on a slant, others have tapped into the oil galleries on side of the head, and others have simply gone with a high volume sump.
Furthering the issues, bellhousing butchery is required.
A 4A is a good option. Many beleive that it lacks spice in NA form in the 1000kg first gen celica chassis, but in GZE trim, it has oodles of torque. Naturally, a well built GTE will outperform the GZE, but you lose some of the responsiveness and low end torque. Read up. There is tonnes of info on these forums. Have a perve in the members rides to see what people have done, and for a good account on the engineering required to put a 3SGTE into an RA28, have a look at Joel's thread. It is lower down this page as we speak.
Click Me...
Good luck.
[Updated on: Sat, 20 August 2005 08:32]
Previous Topic:Knocking
Next Topic:How big does a 4AGE exhaust need to be?
Current Time: Sat Oct 17 22:33:29 UTC 2026
Total time taken to generate the page: 0.0046591758728027 seconds
