Toymods » Tech & Conversions » 240sx strut bar on a ra65
michaelhaynes110
Townsville, QLD, Australia
June 2005
240sx strut bar on a ra65 Fri, 19 August 2005 09:52 Go to next message
I found this writeup on using a 240sx strut brace on an ra65 with a little modification. http://www.speedtoys.com/~teranfirbt/240sx.htm
Now what I want to know is are the 180sx and 200sx bars the same as the 240sx bar? It is just that there are not many available for 240sx cheaply.
On the whiteline website it lists their 180sx strut bar able to be used on 240sx as well...does this mean that I can buy something like this
http://cgi.ebay.com.au/Nissan-Silvia-180SX-200SX-F ront-Strut-Bar-NR-L-K_W0QQitemZ4569555800QQcategor yZ55436QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
off ebay and use it for the application?
Stefan
Hobart, Tas
Re: 240sx strut bar on a ra65 Fri, 19 August 2005 12:39 Go to previous messageGo to next message
AFAIK if it's an early 240sx... i.e. an S13... then it's the same chassis as other S13s (180sx, 200sx etc). I don't know if the front strut bars are different between s13, s14, s15 etc.
michaelhaynes110
June 2005
Re: 240sx strut bar on a ra65 Sun, 21 August 2005 07:29 Go to previous messageGo to next message
Just read the tutorial again and it says 89-94 which is in fact an s13. So I should just be able to use a 180sx brace.
terra
July 2005
Re: 240sx strut bar on a ra65 Sun, 21 August 2005 08:13 Go to previous messageGo to next message
should be fine, australia never got the crappy 240sx and no one ever imported one because theyre shit.
did i mention theyre shit?
(only because we have too much ca/sr aftermarket support here) but the car itself is the same chassis wise.
robakka
Launceston Tasmania
April 2005
Re: 240sx strut bar on a ra65 Sun, 21 August 2005 08:48 Go to previous messageGo to next message
s13 bar will work fine, currently modding one to fit the same car.
michaelhaynes110
June 2005
Re: 240sx strut bar on a ra65 Sun, 21 August 2005 10:21 Go to previous messageGo to next message
robakka wrote on Sun, 21 August 2005 18:48
How hard are you finding it to do? What tool are you using to grind the metal?
robakka
Launceston Tasmania
April 2005
Re: 240sx strut bar on a ra65 Sun, 21 August 2005 10:48 Go to previous message
no worrys from it so far iv done all the cutting with my trusty hacksaw
the end pieces im thinkin about just sending into a metal fabricator of somesort to open up the holes a bit, undecided at this point
basically if u follow the instructions u found u should have no problems
Previous Topic:1G-GTE conversion into a Z10 soarer PICS Its Alive!!!
Next Topic:Hi flow cat for st185
Current Time: Thu Nov 19 09:44:35 UTC 2026
Total time taken to generate the page: 0.0073859691619873 seconds
