Toymods » Tech & Conversions » Some GZE questions
CoronaC
NSW - Blue Mountains
Some GZE questions Fri, 19 August 2005 12:42 Go to next message
First off, did the 4AGZE 4ae92's come out with MAP or AFM sensors? If they were MAP which gen were they (Gen2 im guessing?)
BTW: I searched for this but couldnt find it
And, last one, if the ae92 GZE's came with MAP, is there any difference with the sensors or are they the same?
chris
feral4mr2
Bundaberg, Qld.
Re: Some GZE questions Fri, 19 August 2005 13:43 Go to previous messageGo to next message
http://www.users.bigpond.com/vidore/toyota_4age_en gine.htm
Re: Some GZE questions Fri, 19 August 2005 13:47 Go to previous messageGo to next message
there were two types of AE92 gze's....
pre 10/89 and post 10/89 (month may vary a little)
basically... AFM or MAP.
AFM was a bigport 4A-GZE, with 7 rib block, and coil packs.
MAP was a smallport 4A-GZE.
These are two VERY VERY different motors. Very very few parts are the same between them, in terms of being "identical"
CoronaC
Re: Some GZE questions Fri, 19 August 2005 15:08 Go to previous messageGo to next message
Uhh, made a bit of a mistake in the last question Razz
It was ment to be, is there any difference in the ae92 MAP gze sensor compared to the ae101 MAP gze sensor?
should pay more attention next time Razz
chris
Fujiwara_ToFu
Oakleigh, Melbourne
Re: Some GZE questions Fri, 19 August 2005 19:03 Go to previous messageGo to next message
I think the map's have slightly more hp if that's waht you're after...
Unsure if the map's come with coil packs though...
-Jay
Re: Some GZE questions Fri, 19 August 2005 21:22 Go to previous messageGo to next message
the only differences i know of going from AE92 MAP to AE101 MAP 4A-GZEs are....
# lighter and potentially weaker rods on the AE101 (same rods as 20V, not as meaty as the AE92)
# Twin exhaust system on the AE101, hence the extra coupla kW in factory rated outputs.
# Far greater likelyhood of getting an LSD E58 g'box in an AE101 than an AE92.
# AE101 ECU's have serial data output, and slightly different pinouts
thats all i can think of now...
CoronaC
Re: Some GZE questions Sat, 20 August 2005 00:15 Go to previous message
Alrighty, thanks for the info
chris
Previous Topic:Are ae82 springs different to ae92?
Next Topic:where do i go for tune up in melbourne
Current Time: Fri Oct 30 15:39:48 UTC 2026
Total time taken to generate the page: 0.022053956985474 seconds
