Toymods » Tech & Conversions » Organic vs Button clutch
joorsh
Organic vs Button clutch Sat, 20 August 2005 13:13 Go to next message
I'm looking at clutches at the moment, and my dilemma is this:
I'll be seeing a minimum of 230 rwkw, quite possibly more. Obviously a button clutch would be the best way to go, however I do approx 1000 kms/week, with a lot of that in traffic. With even the mildest button clutch that will still be moderately unpleasant. Will an organic clutch take that sort of power RELIABLY? If so, is there any particular composition I should go for?
I'm told Western Clutches in St Mary's are the go. Can anyone back this up, and/or recommend other places?
clubagreenie
1st street on the right
Re: Organic vs Button clutch Sat, 20 August 2005 13:31 Go to previous messageGo to next message
Perhaps go for a heavier pressure plate and maybe mod the hydraulic system to provide more lever force for the same pedal force.
SL666
Re: Organic vs Button clutch Sat, 20 August 2005 23:21 Go to previous messageGo to next message
call a place called 'raceclutch' its a bloke named jim berry who runs it, ive had a few clutches from him and never been dissapointed..
i'd go with a heavy organic or kevlar style clutch...
Kyosho
Wollongong
Re: Organic vs Button clutch Sun, 21 August 2005 09:45 Go to previous messageGo to next message
Go a ceramic plate, or brass button clutch. 5 Puck.
They're not hard to drive in traffic once you've gotten used to it. And YES you can feather a brass button clutch. Just people who try and do it first time they drive one can't.
I can take off normally in a 5 puck brass button clutch (No huge revs needed etc etc) just nicely take off fairly smooth.
Just learn to drive it. I also couldn't tell too huge of a difference between my standard clutch in my nissan Navara and the 5 puck in the other car I was driving (Regarding force to press it in)
toof
Re: Organic vs Button clutch Sun, 21 August 2005 10:37 Go to previous messageGo to next message
although i havent purchased from jim berry ive got a number of mates that have and have been most happy with his advice and service.
im currently running a 4 puck ceramic in the aw11 and its fine.. was a bit horrid for the first few weeks in traffic but once it bedded in it was tops. and still is. works a treat and isnt too tiresome in traffic. if i had the option again i probaly would have gone witha 5/6 paddle clutch just so its a little softer on the take up but i have no issues with it as it currently is nor does my gf.
joorsh
Re: Organic vs Button clutch Sun, 21 August 2005 11:18 Go to previous messageGo to next message
Skill required isn't the issue here - it's sheer comfort factor. It's just not as pleasant.
Sure you get used to driving a button clutch - I drove one for two years - but that's not the point. When you do as much driving as I do on a daily basis, you want everything to be as easy as possible. There's a reason all cabs are auto.
The other reason is component lifespan. Button clutches are much harder on the drivetrain than the organic ones, especially when combined with a reasonable amount of torque & power.
Sadly I can't afford to have a daily driver and a hobby car, so I just need to find the best compromise. As I said in the original message - I am aware that a button clutch is the best option. I just want to know if an organic one can take this sort of punishment, and if so what compound should I use.
[clubagreenie] Thanks for the tip. Looking into that now.
[SL666] I'll give them a buzz - thanks for the lead.
[Updated on: Sun, 21 August 2005 11:33]
SL666
Re: Organic vs Button clutch Sun, 21 August 2005 21:00 Go to previous messageGo to next message
I drove my GSR with a 4 puck BB sprung centre for a while, it was a great clutch, never slipped, and was 'reasonably' compliant in traffic, but as 'friendly' as a BB can be,i still wouldn't recomend one for someone who drives in serious traffic daily, you won't get the same performance out of a full plate clutch as you would out of a BB, but its also going to be gentler on the driveline..
there are also sprung puck clutches that run different friction material (ceramics or kevlar etc) and have like 10 or so pucks around the friction plate..
seriously though, if you are 'only' looking at around 230rwkw, you should be able to get away with a serious organic or simular... as long as you know it wont stand up to heaps of runs at the drags on a tracion prepped surface (it won't have a problem with a few) however you wouldn't want to run slicks Smile
joorsh
Re: Organic vs Button clutch Mon, 22 August 2005 01:53 Go to previous messageGo to next message
Well 230rwkw is probably where the power will start at. I'm not sure what to expect after a tune. Hoping for 240... possibly even 250rwkw.
Joshstix
Toymods Vice President
Re: Organic vs Button clutch Mon, 22 August 2005 04:58 Go to previous messageGo to next message
What you could do is, take that lovely and much sought after manual setup for the 2JZ and sell it. Then put in an auto for your commuting needs. A well setup auto will be a nice thing in it anyway.
Besides it's only a supra so it's not like you'll be messing up the handling with an auto Wink
Re: Organic vs Button clutch Mon, 22 August 2005 05:03 Go to previous messageGo to next message
or just get an organic twin-plate...
although it's twice the cost of a serious other clutch, you also get twice the clamping force for the same pedal force (since you are doubling the area being pressed against by the pressure plate)
new they are around what? $1000-1200? and that includes the flywheel required?
[Updated on: Mon, 22 August 2005 05:03]
4agte
Toronto, Downtown
Re: Organic vs Button clutch Mon, 22 August 2005 05:09 Go to previous messageGo to next message
ive got a 3 puk ceramic button and its simple to drive with every day i regularly commute to and from work and out to windsor on the weekend and have never had a problem with it.. The clutch is a bit heavy but so was the dakin h/d i had in there b4 hand anyways..
The only issue ive heard with brass button clutches and driving them in traffic is that they tend wear out quicker than organic type clutches this is only what ive heard tho..
Joshstix
Re: Organic vs Button clutch Mon, 22 August 2005 05:24 Go to previous messageGo to next message
oldcorollas wrote on Mon, 22 August 2005 15:03
The ringing sound of a twin plate can be quite annoying in traffic though. In fact I get really embarrased when I pull up at the tolls and people look at me like my car is falling apart just because of the twin plate.
I'm pretty sure they are a LOT more than twice the price of a good single plate as well.
I'd be interested to check out the drivability of an organic twin plate. Mine isn't the best but it is an unsprung ceramic setup rated for 700ps.
Re: Organic vs Button clutch Mon, 22 August 2005 05:25 Go to previous messageGo to next message
ahh k, forgot about that Confused
i just had in mind, sprung centre, cushioned organic face x 2 Very Happy
bbaacchhyy
Re: Organic vs Button clutch Mon, 22 August 2005 06:14 Go to previous messageGo to next message
Speak to Justen, as he has some good experiences.
Extreme clutch here in SA (and on the web) supplied mine, and I got a 5 button sprung centre jobbie, and this should be fine.
It is only the solid centre ones that get really grabby. Norbs shoild have some good hints as well.
Michael B
Re: Organic vs Button clutch Mon, 22 August 2005 23:40 Go to previous messageGo to next message
Yeah, I have a 5-puck ceramic clutch with a sprung centre. Once you're used to it you can drive it quite comfortably in traffic, which I do regularly. I wouldn't trust an organic clutch to reliably hold that sort of power long term. Keep in mind I've had mine for over 2 years and it's still going strong, not a hint of slip ever!
bbaacchhyy
Re: Organic vs Button clutch Mon, 22 August 2005 23:49 Go to previous messageGo to next message
Norbie wrote on Tue, 23 August 2005 09:10
Yeah, just ask his gearboxes and tailshafts how much it doesn't slip !!!!
toof
Re: Organic vs Button clutch Tue, 23 August 2005 00:49 Go to previous message
the one we have in the 4age aw11 is a four puck exeedy sprung centre.. it is pretty easy to drive in traffic and as said above id trust it with that much hp in front of it more then i would a organic.
once you are used to it its pretty polite to drive in traffic you just have to be careful.
my mates levin has what feels like a 6-8puck ceramic sprung centre.. not really sure casue wehavent taken it out and it feels very polite around. infact next clutch for the other mr2 will probaly be something simialr. a hit less agressive then the 4 puck but much much grippier then the organic i currently have in the gze mr2.
Previous Topic:2001 Corolla Sportivo Clutch
Next Topic:AE86 Front coil/damper units
Current Time: Thu Nov 19 20:52:32 UTC 2026
Total time taken to generate the page: 0.0064010620117188 seconds
