Toymods » Tech & Conversions » 18RG Turbo Cooling System Problems
clancey
icon4.gif  18RG Turbo Cooling System Problems Sun, 22 December 2002 06:43 Go to next message
Greetings,
I've recently installed a water/oil cooled T3 turbo onto my 18RGEU motor. However when the motor is under boost water is expelled from the overflow tank.
I'm using the heater lines to cool the turbo (heater no longer connected only the turbo) and i've installed a three core radiator. I've tested the compression of the engine as i have recently installed a 2mm copper head gasket and was worried about the seal.
I doubt the gasket is the problem anyway as the cooling system is fine as long as i keep the car off-boost. (Which isn't much fun Crying or Very Sad).
I was curious whether a higher rated radiator cap is needed as a turbo has been introduced? Currently i'm using a 13psi one.
Any help would be appreciated.
Jeff
feral4mr2
Bundaberg, Qld.
Re: 18RG Turbo Cooling System Problems Sun, 22 December 2002 11:48 Go to previous messageGo to next message
Freak just a idea.....
there wouldnt be a crack in the water jacket housing on the turbo that is leaking boost into the cooling system???
crostek
Oyster bay NSW
Re: 18RG Turbo Cooling System Problems Sun, 22 December 2002 21:35 Go to previous messageGo to next message
Yes your head gasket is blown, as you get the car on boost the compression ratio gets higher and the engine will blow the water out the rad cap from the pressure. If you are really unlucky you could have a cracked head.
clancey
icon4.gif  18RG Turbo Cooling System Problems Mon, 23 December 2002 23:58 Go to previous message
Yeah, i'm suspect to a crack in the turbo myself. The guy from dynamic turbos reckons it's unlikely but I think i'll get the turbo sussed out anyway. Has anyone had this problem before?
The head gasket is under a large amount of pressure normally and it's holding that fine. I find it strange that the increased pressure (with my pissy amount of boost) would be enough to suddenly leak compression into the cooling system.
But if the turbo is ok the gasket/head are the only other possible sources of the problem as far as i can see. So i'll probably get the turbo checked out (as i don't really know it's history) and then check the gasket/head after that.
Jeff
Previous Topic:No TPS on 4AGE
Next Topic:Are Torsen LSD's really ment to be this rough???
Current Time: Fri Oct 16 08:44:13 UTC 2026
Total time taken to generate the page: 0.032427072525024 seconds
