Toymods » Tech & Conversions » 4age crank shaft pully ?? help
rollatoy
August 2005
4age crank shaft pully ?? help Sun, 21 August 2005 03:53 Go to next message
hye guys not asking for a flame im guessing the crankshaft pully comes off anti clockwise i have searched the shop manual and the forum and couldent find anyinfo i need to know how to pull it off and how to secure the crank so it dosent turn while im takeing the pully off
d-shiznit
W.A
Re: 4age crank shaft pully ?? help Sun, 21 August 2005 05:09 Go to previous messageGo to next message
Easiest way is to use a pulley remover tool from any auto shop.
The pulley comes straight off btw, you don't twist it off..
If you're trying to stop the crank turning, try sliding a large screwdriver through the crank pulley and wedged against the block... thats how I got the crank pulley bolt off.
[Updated on: Sun, 21 August 2005 05:13]
Dale_ta22
Forster NSW
Re: 4age crank shaft pully ?? help Sun, 21 August 2005 06:45 Go to previous messageGo to next message
anti clockwise
righty tighty, left loosey Wink
Unless you've got the gearbox off good luck securing the crank from turning.
You've got a few options:
1) use a rattle gun
2) position a breaker bar so it will wedge against the chasis when the motor is turned over, crack the starter, and your bolt is undone. - you can probably wedge the bar against the ground even, depending - that's the way I've done it.
3) fill one cylinder with oil or water and put the spark plug back in. When done, take spark plug out and turn motor over by hand to blow the water out of the cylinder - oldcorollas idea, but I love it
4) wedge a large screwdriver in one of the flywheel teeth (if gearbox is off)
Number 2 likely being your best bet.
rollatoy
August 2005
Re: 4age crank shaft pully ?? help Sun, 21 August 2005 07:24 Go to previous messageGo to next message
its ok guys i got it off and it was the bolt i needed to undo the pully slid off like slideing outa virgin Wink the motor was outa the car and had sump off so i just carefully wedged the crank from the inside and used a huger steel bar for leverage and pop off she came now i need to go find one of the torque things to get the weired head bolts off anyone know what size and name of it is
d-shiznit
W.A
Re: 4age crank shaft pully ?? help Mon, 22 August 2005 00:13 Go to previous messageGo to next message
10mm socket????
rollatoy
August 2005
Re: 4age crank shaft pully ?? help Mon, 22 August 2005 01:36 Go to previous messageGo to next message
nope it has spines on it and cant get a socot on it i look like * sorta thing
d-shiznit
W.A
Re: 4age crank shaft pully ?? help Mon, 22 August 2005 02:19 Go to previous messageGo to next message
Yeah my sockets are like that...
Mine was just a cheapo set from auto1.
Borrow from your neighbours!
rollatoy
August 2005
Re: 4age crank shaft pully ?? help Mon, 22 August 2005 02:23 Go to previous messageGo to next message
ok i know what socets ur talking about i have one sorta like it but dosent quite fit ill see if i can d find someone thats got one
towe_001
Somewhere on a dirt bowl ...
Re: 4age crank shaft pully ?? help Mon, 22 August 2005 08:49 Go to previous message
The socket in question is a 10mm 12 point deep socket. Or you can go to toyota and ask for SST09205-16010
Previous Topic:K-Mac Strut Tops, Bent!
Next Topic:overheating and major loss of power
Current Time: Wed Aug 5 03:51:14 UTC 2026
Total time taken to generate the page: 0.0049920082092285 seconds
