Toymods » Tech & Conversions » 18rgeu engine parts
2syco
18rgeu engine parts Sun, 21 August 2005 07:16 Go to next message
I have just put together my 18rgeu and was wondering what some of the parts are on the engine. I have an aftermarket computer so i have a new wiring loom.
At the end of the fuel rail is a devise with a bleed valve on it. Where does that connect to? I will try and attach some pictures of other parts that i am unsure about.
Any help would be appreciated.
people100
Rocklea qld
Re: 18rgeu engine parts Sun, 21 August 2005 09:05 Go to previous messageGo to next message
what end of the fuel rail? is it on top or underneath. if its underneath at the fan end then its the inlet. no bleeder there. if its at the gearbox end and underneath its the regulater and if its ontop at the fan end its where the cold start injecter would have been. im guessing you didnt build the engine if you no nothing about it.
2syco
Re: 18rgeu engine parts Sun, 21 August 2005 09:24 Go to previous messageGo to next message
if you are so smart then you would know that at the gearbox end underneath is a bleed valve on the regulater and that is what i was asking about. Next time dont bother posting a reply if you have nothing good to post!
I thought this site was designed for people to get information not to get smart arse comments.
people100
Rocklea qld
Re: 18rgeu engine parts Sun, 21 August 2005 09:31 Go to previous messageGo to next message
ok then smart ass. 2 things. firstly if you know its a bleed valve which usually means to bleed something out, why the hell are you asking where it goes. obviously its goes nowhere because its just to bleed with. and secondly are u sure its not just a vacuum line. i think it is and it prolly goes to the manifold where most vacuum lines go.
Re: 18rgeu engine parts Sun, 21 August 2005 10:00 Go to previous messageGo to next message
2syco wrote on Sun, 21 August 2005 19:24
... then you would know that at the gearbox end underneath is a bleed valve on the regulater and that is what i was asking about.
that would be manifold vacuum reference for the Fuel Pressure Regulator - if it's a small tube on the back of the device
rail should have three conections (fuel in, cold-start injector and FPR on the exit) - apart from the injectors.
cheers,
Charles.
barned01
Re: 18rgeu engine parts Sun, 21 August 2005 10:12 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=70103&rid=3721&S=d1c39721cc595de43672955 41965c636&pl_view=&start=0#msg_692528
this thread contains a couple of pictures of my vaccuum lines on my engine (in the hunt for trying to work out why it didn't cold start idle which ended up being the complete lack of an idle control valve)
if you look at the second to last picture it shows the bottom of the fuel pressure regulator, there is indeed a vaccuum line as people100 stated, that goes into the manifold via a 'T' piece that also breaks off to the vaccuum advance/retard on the distributor (although i have been led to believe this may not be the correct dizzy internals so ignore that bit).
the main thing is the line goes from the regulator to the manifold though (follow the yellow lines)
hope it helps ya matey
barnsey
2syco
Re: 18rgeu engine parts Sun, 21 August 2005 10:48 Go to previous messageGo to next message
Thanks Barnsey and Charles thats helped heaps!!!!
omegaman
SYDNEY
Re: 18rgeu engine parts Sun, 21 August 2005 12:12 Go to previous message
just emailed you 2 pages of that file.
good luck
[Updated on: Sun, 21 August 2005 12:12]
Previous Topic:4AGZE
Next Topic:1G-GTE conversion into a Z10 soarer PICS Its Alive!!!
Current Time: Thu Nov 19 10:03:19 UTC 2026
Total time taken to generate the page: 0.0052280426025391 seconds
