Toymods » Tech & Conversions » overheating and major loss of power
Durrie1986
August 2005
overheating and major loss of power Sun, 21 August 2005 12:21 Go to next message
hi about 2 days ago i noticed my car losing power and sounding like a truck i replaced manifold gasket and it stopped being loud still hasn't gained any power though and the radiator bubbles if you leave the cap off. no sign of oil in the coolant but it overheats and doesn't go hard anymore. i own a 90' seca sx 100kw 4AGE any help would be great. durrie
havabeer
new castle
July 2005
Re: overheating and major loss of power Sun, 21 August 2005 12:45 Go to previous messageGo to next message
could the head gasket be stuffed?? i've been told car over heats pretty bad if head gasket is gone.... also could the temp sensor not be working properly??
Re: overheating and major loss of power Mon, 22 August 2005 06:30 Go to previous messageGo to next message
Durrie1986 wrote on Sun, 21 August 2005 22:21
... overheats and doesn't go hard anymore
head gasket?
radiator clogged? (it it able to keep control of temps on the highway?)
when you replaced the manifold gasket, did you get all the piping/wiring hooked up the right way?
4agte
Toronto, Downtown
Re: overheating and major loss of power Mon, 22 August 2005 07:34 Go to previous messageGo to next message
do a compression test if it reads low on a cylinder or 2 then pour a small ammount of oil down the cylinder and if the compression improves its a head gasket.
Otherwise try flushing the coolant and replacing with toyota red coolant or a coolant that is compatible with toyota motors.
Another thing it could be is that the thermostat is staying shut so it may pay to replace that aswell..
Could also be your ignition timing may be too advanced check to make sure the timing is correct
Re: overheating and major loss of power Mon, 22 August 2005 08:10 Go to previous messageGo to next message
4agte wrote on Mon, 22 August 2005 15:34
Thats a test for rings, not for head gasket.
pops_1j
hunter valley
March 2005
Re: overheating and major loss of power Mon, 22 August 2005 08:15 Go to previous messageGo to next message
sounds to me like water pump same problem with my old 7m motor
4agte
Toronto, Downtown
Re: overheating and major loss of power Mon, 22 August 2005 08:32 Go to previous messageGo to next message
CrUZsida wrote on Mon, 22 August 2005 18:10
wooops indeed your right sorry
pops_1j
hunter valley
March 2005
Re: overheating and major loss of power Mon, 22 August 2005 08:35 Go to previous message
are you being smart?
Previous Topic:4age crank shaft pully ?? help
Next Topic:engine removal plz help
Current Time: Sun Nov 22 14:40:42 UTC 2026
Total time taken to generate the page: 0.0058779716491699 seconds
