Toymods » Tech & Conversions » can u get rid of 'diff whine'
lewy
June 2005
can u get rid of 'diff whine' Mon, 22 August 2005 00:07 Go to next message
is it possible to get rid of chronic diff whining??? like without banana skins Confused mines so loud its almost un bearable hahah
mideon_696
wollongong
Re: can u get rid of 'diff whine' Mon, 22 August 2005 00:20 Go to previous messageGo to next message
did u check the oil. my ol pinney was famous for it, lol, we'd check the oil in it, fine, apparently, lol, til one day i decided to change the gasket and oil in it, when i put the new shit in, she took about 3 times as much, the whine didnt dissapear, but was barely audible inside the cabin..
otherwise, lol, fill her with banana's Rolling Eyes
Re: can u get rid of 'diff whine' Mon, 22 August 2005 00:21 Go to previous messageGo to next message
dont talk to me about whiny diffs haha.. i am so f*^ked off by them. been through 3x T series in the AE86 over the last few months.. followed by some F series in the RA28.. now the 4runner diff is whiny!
i'm lead to believe it is either the pinion bearing or more than likely buggered ring & pinion gears.
I dont seem to be able to find such thing as good secondhand ring & pinion gear anymore.. all old and worn..
I reckon the only good diff lewis was the one S series one in the ae86 when I sold it.. came out of a low km, automatic car.
[Updated on: Mon, 22 August 2005 00:22]
Re: can u get rid of 'diff whine' Mon, 22 August 2005 00:48 Go to previous messageGo to next message
about all you can do is readjust the positions of the crown and pinion to set the backlash and contact position.. with luck it may wear itself into the new position. better to do it sooner rather than later..
or it may be stuffed....
4ageeza
Adelaide, drift capital
Re: can u get rid of 'diff whine' Mon, 22 August 2005 01:39 Go to previous messageGo to next message
I had a T18 once with a leaking gasket around the diff centre. I didnt get around to fixing it until it starting making some horrible whine. When I removed the centre...it had about 200mls of oil in it Confused
Even after replacing the oil and gasket, the thing would still whine like a biarch. The crownwheel and pinion obviosly experienced some accelerated wear.
ZZT231
melbourne.vic.au
Re: can u get rid of 'diff whine' Mon, 22 August 2005 04:42 Go to previous messageGo to next message
With my MA61 once got the new center installed (and didn't replace the pinion bearing), my pinion bearing was worse for wear so I replaced it and got rid of the whine. I had a continous clunking sound in the SA63 but found out later it was the uni joints on the tailshaft which failed Sad
See if you can find friction modifer if it's not the bearings otherwise you might have to rip the diff open and see what is happening on the inside.
Cheers.
dingaling
tas
Re: can u get rid of 'diff whine' Mon, 22 August 2005 06:56 Go to previous messageGo to next message
How about getting rid of Diff clutch shudder, chatter, lumpyness, ruffness and clicky noisyness?
I buahgt a really tight G series 4:3 diff. had castrol LSD oil in it, it chattered and chugged on slow turns, quite anoying. Then when i was in melbourne i was sold "premium" real good LSD oil! the best! $20/litre, so i was told from a fellow toymodder. So i tried that out and my Diff wants to rip itself apart!! Totally undrivable with this oil in there, not very happy! When the oil does allow the clucthes to slip the whole car feels like the wheels are square shaped! the voilent vibrations and noises it makes really send shivers down my spine! (won't mention any names, but your oil is not so good for my diff)
So any recomendations for a GOOD proven LSD oil for G series clutch LSD's?
I have heard redline is good, but here in tas nobody seems to sell it.
Re: can u get rid of 'diff whine' Mon, 22 August 2005 07:21 Go to previous messageGo to next message
one mans good may not be another mans Wink
it sounds like it has too much friction.. which is eactly what you want for a worn LSD ....
as for original post.. just chuck in some lead or solder filings Shocked
dingaling
tas
Re: can u get rid of 'diff whine' Mon, 22 August 2005 10:33 Go to previous messageGo to next message
worn you say? nah
she's alright now, drained out the "special" LSD oil out and whent back to the castrol lsx90. Will try redline diff oil when i can get ahold of it. But it's now reduced to a couple little clutch chutters here and there as it works it's way thru the clutches.
AH! it clicked! i see what you ment with the worn lsd bit now, and i think your quite right.
[Updated on: Mon, 22 August 2005 10:35]
Driftspec
Re: can u get rid of 'diff whine' Mon, 22 August 2005 11:49 Go to previous messageGo to next message
Can't go past Redline OIL, I have used it in my trans on the old car (Skyline), I had syncro issues, this stuff took it away completely.
I gather the right Redline Oil will do your diff wonders.
Wezelton
Sunshine Coast
Re: can u get rid of 'diff whine' Tue, 23 August 2005 02:45 Go to previous messageGo to next message
The whole drive line of my car seems to shudder since i dropped the back more, feels like the whole axel is loose (ra60). I do remember that my mates S12 would shudder up the tail shaft when it was mega low, said it was the uni joint angle, anyone looked into that ? Also my diff whynes like a whore since i cranked donuts one day.. Confused its locked but it was fine for a few weeks.. the diff leaks a bit so maybe she's low now lol
Whats this talk on bananas in the diff ? haha sounds fun to me.
wes
ke1500
Re: can u get rid of 'diff whine' Tue, 23 August 2005 03:33 Go to previous messageGo to next message
USE HEAVY DUTY GEARBOX OIL. IT'S 110wt INSTEAD OF 90w. HELPS A BIT. IT'S MENT FOR TRACTORS. YEEHA
Re: can u get rid of 'diff whine' Tue, 23 August 2005 04:48 Go to previous messageGo to next message
Thicker oil masks the problem but doesn't fix it. There's no easy way out of this, take it to a diff shop and get it fixed properly!
Lachie
Re: can u get rid of 'diff whine' Tue, 23 August 2005 05:10 Go to previous messageGo to next message
Wezelton wrote on Tue, 23 August 2005 12:15
wes
You put some bananas in the diff just like it sounds!
All it does is thicken up the oil so it masks the nosie, but like Norbie said, better off getting it fixed or just put a new centre in
Re: can u get rid of 'diff whine' Tue, 23 August 2005 05:19 Go to previous messageGo to next message
The old banana peel trick is extremely temporary of course. It's an old favourite for dodgy people trying to sell a car with a rooted diff.
Wezelton
Sunshine Coast
Re: can u get rid of 'diff whine' Tue, 23 August 2005 08:05 Go to previous message
I ran 110w lsd oil last time, it was good.. maybe i should go it again.. any idea on the shuddering tho ?
Previous Topic:Diff Ratio
Next Topic:suspension questions
Current Time: Sat Nov 21 19:19:29 UTC 2026
Total time taken to generate the page: 0.0057179927825928 seconds
