Toymods » Tech & Conversions » Fitting AE101 Headlights into AE102
birdie
Coalstoun Lakes
Fitting AE101 Headlights into AE102 Mon, 22 August 2005 08:56 Go to next message
i bought some AE101 headlights from a user of these forums (who bought them for his rolla but pranged the rolla before he got the lights)
I have an AE102 Corolla Seca, which as far as I'm aware they are same chasis as the AE101 (just a 7AFE instead of a 4AFE).
Now I went to install the headlights this afternoon, but there are a couple of minor differences.
These are the two headlights:
http://www.birdiehq.net/images/IMGP0851Medium.JPG
This is the new headlight, notice how the grill "clip" faces forwards:
http://www.birdiehq.net/images/IMGP0853Medium.JPG
http://www.birdiehq.net/images/IMGP0856Medium.JPG
This is the old headlight, notice how the grill "clip" faces upwards:
http://www.birdiehq.net/images/IMGP0854Medium.JPG
http://www.birdiehq.net/images/IMGP0855Medium.JPG
To fix this, i guess I have two options; to get an AE101 Grill that uses those clips or build a custom grill. The new Headlight looks slightly more rounded on the inside, so I'm fairly sure I woun't be able to use the standard grill?
This is the base of the old headlight, notice the clip method:
http://www.birdiehq.net/images/IMGP0857Medium.JPG
http://www.birdiehq.net/images/IMGP0860Medium.JPG
This is the base of the new headlight, notice there isn't a clip but there is a buldge there.
http://www.birdiehq.net/images/IMGP0858Medium.JPG
http://www.birdiehq.net/images/IMGP0859Medium.JPG
birdie
Coalstoun Lakes
Re: Fitting AE101 Headlights into AE102 Mon, 22 August 2005 08:58 Go to previous messageGo to next message
More images, 10 image/post limit
This is the clip that the old headlight clips into:
http://www.birdiehq.net/images/IMGP0864Medium.JPG
http://www.birdiehq.net/images/IMGP0865Medium.JPG
http://www.birdiehq.net/images/IMGP0866Medium.JPG
I'm not sure how to fix this? I can unscrew the old clip but the metal tab is still in the road a bit, i could bend it down a bit I guess?
The final difference is the plugs:
The new headlights, seperate low beam and high beam:
http://www.birdiehq.net/images/IMGP0861Medium.JPG
The old headlights, combined low and high beam:
http://www.birdiehq.net/images/IMGP0862Medium.JPG
http://www.birdiehq.net/images/IMGP0863Medium.JPG
This should be easy enough to change, just snip the old plug and rewire with new plugs.
NuGeN
Re: Fitting AE101 Headlights into AE102 Mon, 22 August 2005 10:23 Go to previous messageGo to next message
Have u tried fitting the new headlight insides and cover to your old headlight casing?
Should fix your mounting problems if it works...
birdie
Coalstoun Lakes
Re: Fitting AE101 Headlights into AE102 Mon, 22 August 2005 10:37 Go to previous messageGo to next message
NuGeN wrote on Mon, 22 August 2005 20:23
Nah won't work. slightly diffent shape (see the inside edge) and different plugs on the back too.
Thanks though Smile
birdie
Coalstoun Lakes
Re: Fitting AE101 Headlights into AE102 Tue, 23 August 2005 10:31 Go to previous messageGo to next message
I found out i need the USDM grille and corner lights (i'm getting clear parkers, and they were from America so they should be USDM Very Happy), now I just need to find a USDM grille
mideon_696
wollongong
Re: Fitting AE101 Headlights into AE102 Tue, 23 August 2005 11:09 Go to previous message
i thought clear parkers were standard on ae102? mine r clear....
sweet lookinging headlights bro. u gotta get a TRD grill
Previous Topic:manual conversion for soarer?
Next Topic:100kw 4age redline
Current Time: Sun Nov 1 05:02:08 UTC 2026
Total time taken to generate the page: 0.0049290657043457 seconds
