Toymods » Tech & Conversions » Sync + Reference triggering (wolf3d) and 1ggze CAS
rx793
Perth, Western Australia
Sync + Reference triggering (wolf3d) and 1ggze CAS Mon, 22 August 2005 11:39 Go to next message
Hey guys, ive done a bit of reading about hooking up the CAS on the 1ggze. Its the reluctor type, and from what i know sounds very similar to the 4AGZE CAS. Is anyone able to explain, how i go about setting it up? I mean, from what i can see, i have 1 trigger magnet on the 24 tooth wheel, and 2 magnet pickups on the top (or single tooth). Is anyone able to explain to me how to set it up becasue the wolf 3d manual totally bamboozals me, can anyone basicly tell me if its the same as the 4agze or what?
Steve
Re: Sync + Reference triggering (wolf3d) and 1ggze CAS Mon, 22 August 2005 12:06 Go to previous messageGo to next message
not sure if it'll help you decode the wolf info, but this goes into a fair amount of detail of Toyota systems ...
Ignition Systems: http://www.autoshop101.com/forms/h23.pdf
Input sensors: http://www.autoshop101.com/forms/h24.pdf
other info in the technical articles section at: http://www.autoshop101.com/
rx793
Re: Sync + Reference triggering (wolf3d) and 1ggze CAS Mon, 22 August 2005 13:23 Go to previous messageGo to next message
Huge help mate, thats just what i needed to get my head around it.
I have now wired it up accordingly using the "G2" (Cyl 1 BTDC), much the same as the 4agze! Now i should be able to start her up for the first time, i will let you all know how it goes, any other tips that might help?
Re: Sync + Reference triggering (wolf3d) and 1ggze CAS Mon, 22 August 2005 13:58 Go to previous messageGo to next message
Yup - use the Wolf 'reluctor adapter' if you want any kind of consistant triggering!
rx793
Re: Sync + Reference triggering (wolf3d) and 1ggze CAS Mon, 22 August 2005 14:36 Go to previous message
what is that?
Previous Topic:Car smoky...blown turbo?
Next Topic:Crank Triggers - 4AG 100KW vs GZE
Current Time: Fri Nov 20 00:49:46 UTC 2026
Total time taken to generate the page: 0.011548042297363 seconds
